High Current, High Side Driver Help Needed
Roddy Wayne
Apr 28, 2015
Hello Group,
This is my first post to this group.
My problem is, I have Eight 12 Volt Lamps that I want to control with a PIC. These lamps have their screw shells already grounded so, I need to control the Positive 12 Volts going to the lamps. Each lamps current is about 2.2 Amps but, the inrush current could be several times as much. I am looking for any recommended Transistor Drivers / Circuits that could be used in this application.
Thanks for any help!
Rod
ADRT
Nov 25, 2014
192
I use IRF540's for a lot of my high power projects. They are relatively easy to find and can handle some pretty high currents and voltages, but are easily triggered with an output from my Arduino without putting undo strain on the output. Can easily be used in conjunction with an opto isolator if concerns of damaging controller output.
ADRT
Nov 25, 2014
192
Sorry that's wrong. I wasn't taking into account that you where switching on high side of the LED.You would need a PNP MOSFET instead. This one should work fine for what you are doing and is reasonably priced.
https://www.sparkfun.com/products/10349
