High Vin LDO with truely low dropout in small package (long post)
rickman
We often need to power low current circuits (<100 mA) from a wide
battery voltage of 7 to 16.5 volts. It is hard to find switching
regulators that will do this efficiently. Sometimes we can just write
off the wasted power and use an LDO if the current is low enough, but I
am looking to find a way to reclaim this lost efficiency.
I am thinking of building a switched capacitor voltage converter that
can lower the input voltage over this input voltage range to something
that is suitable for an LDO. The circuit would use a CPLD (powered by
this circuit) to generate the control signals for a small army of P and
N channel FETs (or possibly analog switches) to control three flying
capacitors. I have done a lot of searching and found a 2 x 3 mm
complementary FET that has the required characteristics that should
work well. I have also found a 4 channel comparator with a built in
reference. Now I only have two remaining problems.
The first is figuring out how to start up the circuit. I have come up
with a couple of ideas that will bypass the switches until the output
voltage is up to snuff and the CPLD starts running the switches.
However this is hard to do without exposing the LDO following the
switched cap converter to the full Vin of 16.5 volts.
This is the second problem. If I try to find an LDO with Vin up to
16.5 volts, output current up to 100 mA and dropout voltage of 200 mV,
I come up short. Considering some losses in the switching circuit,
even to work with a dropout of 200 mV will realistically require the
output voltage to be lower than the 3.3 volts I would like to use. But
I can likely live with 3.2 or even 3.1 volts if the accuracy on the LDO
is good enough to keep it above 3.0 volts worst case.
I can't raise the 7 volt Vin minimum requirement, so I am stuck with a
200 mV dropout. I can get this in a low Vin device, but not a high Vin
device in a small package. So far I have tried to keep this as simple
as possible and not used anything like a "pre-regulator" or Zener
diode. But I'm not happy with my choices.
Anyone have any suggestions on a better way to improve this circuit?
John Larkin
Revisit the idea of using a buck switcher? That doesn't seem difficult
over a mere 2:1 or so input range, and it will be a lot simpler than a
switch+cap array, control logic, and an LDO.
John
U
Uwe Bonnes
Did you look at the Texas Instrument TPS 6211X family?
rickman
Yes, simple, but very inefficient. At 100 mA it may not be so bad at
around 50-60% typically, but at 10 mA or lower the efficiency goes to
heck in a handbasket. The high Vin parts are all designed for 1.5 amps
or higher so the efficiency goes south at lower currents. They
typically get around this by using pulse skip mode or something
similar, but we can't use that because we have to synchronize the freq
to a common clock to help deal with the EMI.
Thanks for the thought though. Yes, I only wish someone would make a
decent low current, high Vin switcher.
rickman
These are not LDOs. They are inductive switchers. The problem is
efficiency. Since we have to use PWM mode only, the best it will do is
reaching 80% at 100 mA. But the efficiency gets quickly worse at lower
power levels. Below 6 mA an LDO is more efficient even at 17 volts and
is still better at low Vin up to about 25 mA. Since this circuit will
be powered 100% of the time the efficiency matters even at the lower
power levels. The switched cap circuit can stay above 80% over all
voltages and down to 1 mA I estimate.
U
Uwe Bonnes
Why do you you have to stay with PWM mode only?
U
Uwe Bonnes
For the High Vin LDO did you look at the Zetex ZLDO Series? The Torex
XC6202 Series might also fit if you only need 100mA and is cheaper and
smaller.
John Larkin
A simple homemade hysteretic switcher should be efficient down to
roughly zero current, if you allow a bit of ripple. As far as syncing
with a clock to reduce EMI, well, I don't understand that... isn't it
better to spread out the spectral lines instead of heaping them all on
top one another?
John
rickman
smaller.
PWM mode has to be used because the switching has to be synchronized
and you can't do that in PFM.
Thanks for the suggestions. I don't know all the LDO makers and I
figure I would get a few tips. The Torex part is not so low a drop out
voltage at 670 mV, even at 30 mA it is 200 mV. The Zetex part looks
like it will be a good choice although it comes in a larger package
than I would prefer. It also is a fixed output voltage and the range
is wide at about 3% tolerance. But this may well work. I don't know
for sure what my range will be at the switcher output. We'll see when
I prototype the circuit.
rickman
top one another?
Two problems with that idea. First spreading the spectrum may or may
not reduce the problem. For example, using a moving frequency for the
clock may result in a test measurement that is lower, but does it
really reduce the interference problem or does it just allow you to
pass a test? The interfering spur is still the same amplitude, it is
just moving while you test and so is integrated over a wider frequency
range giving an average lower reading.
Secondly, in the case of power supplies, you will be generating spurs
either way, sync'd or not sync'd. But if you sync all the supplies to
the same clock, at least they are all creating the same harmonics.
There are other ways to deal with the spurs since you can't get rid of
them.
If it is easy to make a switcher with good efficiency at low currents,
why aren't there chips available to do that? We get a fair amount of
attention from the vendors because we sell a lot of units. They all
try to sell me the same 1.5 Amp high Vin switchers with low efficiency
at low currents. The TI part is the best one I have seen so far and it
is terrible below about 30 mA.
John Larkin
pass a test?
What matters, other than passing the test?
Exactly. But I wasn't suggesting deliberate dithering or anything,
just wondering what advantage there might be from syncing the switcher
to the system clock.
them.
Dunno. I did say "homemade."
John
John Popelish
(snip)
Have you looked at National's LM2736 to do the whole job?
Efficiency at 3.3 V and 100 mA out is 70% with 18 volts in
and 34% at 10 mA out. With a 5 volt supply those two
efficiencies rise to 86% and 62%.
http://cache.national.com/ds/LM/LM2736.pdf
The slightly simpler LM2674
http://cache.national.com/ds/LM/LM2674.pdf
wastes about 3 mA plus switching losses, and might also work
for you.
I'm missing something here. The minimum input voltage is 7V. The output
is 3.3V. Just how does this work out to a drop out voltage of 200mV?
Can't you buck the input down to 4.3V, and use just about any LDO.
Having designed a few SMPS, there are plenty of gotchas. You are always
better off buying an IC controller. There is much black magic in
controller chips that the user never sees, mostly related to
undervoltage lock-out and start-up situations.
rickman
John said:
This one (LT3470) has even better efficiency at low current
and a low parts count:
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1003,C1042,P8810,D6297
Output at 3.3 volts:
With 7 volts in and 1 mA out, 74%.
With 7 volts in and 100 Ma out. 80%.
With 24 volts in and 1 mA out, 64%.
With 24 volts in and 100 mA out, 72%.
Thanks for the tips, but I have looked at all of these devices as well
as many more. This is the third time I have done this same power
supply search for these parameters. If there was an inductive switcher
out there that did a good job at 10 mA of current, I would have found
it. But the combination of low current and high Vin seems to be
deadly. In addition, all but a few of the high Vin regulators are
non-synchrnous and many of those also require a boost diode. By the
time you add the sizes of all these components you are using a fair
hunk of real estate and not getting much in the way of efficiency.
Designing an inductive switcher may well be complex. But a multimode
switched capacitor circuit is mostly a digital design along with
careful control of the detailed timing. The only timing issue I am
concerned about is that the P channel FETs must be driven through N
channel FETs. These devices add much more delay to the path than the
logic circuits will. To make sure there is no shoot through I will
have to compensate these delays compared to the N channel FETs used on
the low side of the caps. I may have to add N channel FETs to drive
the N channel FETs just to equalize the delays.
But what I asked for help on was selecting an LDO that meets my
requirements.
rickman
Yes, you missed that I am using a switched cap voltage divider in front
of the LDO. Inductive switchers are too inefficient. Between input
voltages of 7 to 10.5 I expect to use a 2:1 divider and higher ratios
at higher voltages. This gives me 3.5 volts to the LDO if the switcher
is optimal. I expect the switcher drop out to be minimal as the FETs
I am using are sub ohm resistance. I found nice small complementary
FETs in a 2x3 mm package rated for healthy currents and low voltage
drive. So assuming I loose 100 mV in the switcher and 200 mV in the
LDO, I can still get 3.2 volts out of the LDO. If the tolerance
(including set resistors) is +-3%, I can set it for 3.1 volts and it
will not be below 3.0 volts or above 3.2 volts meeting all the limits.
I do have some concerns about the losses in the switcher. But if they
are too high to run the switcher and LDO from 7 volts, I can always add
a 1:1 mode for the low end of the input voltage.
Rocky
Just out of curiosity - what frequency will the switcher run?
Regards
Rocky
Jim Granville
The LP2951/LP2954 family get close. Micrel & Advanced Monolithic do
'better' versions of these, with -20/+60V ip.
You could also look at placing the LDO _before_ the switch-cap, since
you say that has low Rs. That halves the LDO current, and also makes the
dropout a smaller % of higher voltage.
Also, because you DO have a higher voltage, that opens up boosted gate
drive schemes, most often found in higher current regulators.
Have you looked at LED drive Switch modes ? - these are getting smarter
all the time, and often have mode changes, and are designed to deliver
low load currents, at high efficencies - because they target handheld apps.
-jg
Rene Tschaggelar
them.
A switcher in burst mode has less transients than in
PWM mode. Thus generates less EMI. If you want low
EMI, then you have to choose a switcher with
controlled/slower transients.
Rene
rickman
I believe I could run it at any freq and still meet the "requirements".
There is a common signal to sync switchers at 600 kHz which I will
use. The intent is to sync the inductive switchers since they radiate.
I believe the switched cap circuit will be much quieter and so should
not need to be run at this freq, but I will sync it just to ward off
the kibitzing.
