rickman said:
John Popelish wrote: (snip)
I can't work with the variable frequency so I am stuck using the parts
in the PWM mode which has too low an efficiency.
I don't understand why you can't work with variable
frequency, if you keep the noise under control.
Why is theoretical efficiency even an issue? I have a design that over
a range of current will provide efficiencies between 70% and 95%
including the required drop out of the LDO. Of course this is not
built or tested so it may end up having some higher losses than I
expect due to quiescent current.
Any time you connect two capacitors together that do not
match in voltage, as much energy is lost as is transferred.
The switch is essentially a resistor in series with the
charge transfer.
This circuit is not to deal with EMI. Besides, this should have a lot
better EMI performance just because there is no inductor.
Inductors are not inherently noisy. A shielded inductor can
be part of a very useful noise filter.
The reason for this design is efficiency.
You may teach me something new, if you can achieve high
efficiency with a switched capacitor voltage changer.
And when charge plows between two of those capacitors
through the low impedance of your switched, large current
pulses (many times the average load current) will occur, and
those can radiate a lot of noise, if you aren't careful.
Please explain how I can improve the efficiency of the inductive
switcher at 10 to 30 mA of output current. The simple inductive
switcher is not large. But it is not efficient at low currents either.
I don't understand how adding circuitry can improve that.
The LT3470 claims an efficiency of 64% with 24 volts in, 3.3
volts out and a 1 mA load (better with a 16 volt to 7 volt
input). If you add a small inductor to the input side and
maybe a ferrite bead to the output, the noise level can be
quite low. The frequency is, however variable, since this
part is a hysteretic controller. But that means that it
handles step load changes with guaranteed stability. The
main filter inductor could be less than 7mm square, like the
100 uHy Sumida CDRH6D28NP-101ND @ $1 each:
http://www.sumida.com/en/products/pdf/CDRH6D28.pdf
