High Vin LDO with truely low dropout in small package (long post)
rickman
John said:
I stand corrected on the efficiency possible. I just
simulated a 2 to 1 voltage switched capacitive voltage
reducer, and if the switch on resistance was low enough,
good efficiency was possible. But the large current spikes
I mentioned were also present. If I use a two phase, high
frequency 2 to 1 step down, everything quiets down pretty
well.
High frequency is the key. The high current spikes you mention are
caused by the voltage differential combined with the low ESR of the
caps. There is a peak of current at the onset of switching which ramps
down as the voltages equalize. Then the current is strictly the load
current which will ramp up the voltage on the high side cap(s) and ramp
down the voltage on the output and low side caps.
By using a high frequency the initial delta V on the caps is smaller,
reducing the spike current. The two phase circuit will also help, but
it quickly becomes impractical for anything other than a 2:1 divider.
To work well over a 7 to 17 volt input range, I am planning to
implement 2:1, 3:1 and 4:1 voltage ratios and may even use 2.5:1
although that would just be icing on the cake to boost the efficiency
over a fairly narrow range of Vin (8.5 to 10 volts).
Mark Borgerson
Any number of things may be possible, but I have not yet found a
converter chip which will allow synchronization in PFM. In fact, they
typically use the same pin for selecting PWM/PFM and clock sync input.
The pin can not be held low and receive a clock at the same time.
I suppose that you could simply use a comparator and gate to halt
the switcher---through a shudown input or by gating the clock.
This could all be moot if you are constrained on size---you will
probably need a pretty large capacitor. However the super caps
are getting better all the time.
Mark Borgerson
rickman
I'm not sure how this would be a better approach to this problem. It
seems to be pushing the limits of what you can do with a switcher. I
can't recall the startup times for switchers, but this sounds to me
like it could be a very tricky circuit to get to work correctly over
all conditions, especially when you add in something like a super cap
that has very limited temperature range.
I think the point is moot now. The last thing I needed to check to see
if it was viable was the drive for the PFETs. When I calulated the
drive current required, I have a choice of switching them fast, or
switching them with low current, I can't do both. I did not know that
discrete FETs were so limited for speed. The part I had selected has
an input capacitance of 600 pF!
This type of circuit might be practical inside a chip, but using
discrete components makes it slow and unwieldy.
Jonathan Kirwan
FAB capacity has been brokered for some time, now, and the pricing
isn't scary. And also offered to universities at still lower prices.
You might be able to get a decent number of your chips made at fairly
okay costs and then shop them around. Just a thought.
Jon
John
Rick,
This is the second problem. If I try to find an LDO with Vin up to
16.5 volts, output current up to 100 mA and dropout voltage of 200 mV,
I come up short.
Will this work for you? : http://www.national.com/pf/LP/LP2980.html
I'm using the AIM-3.3V of this part in a design and it sounds like it's
almost a perfect fit. Perhaps parallel two of them or use an external
FET to get the 100 mA continuous.
John.
Jim Granville
John said:
Rick,
and this one looks a very good reality-check for any alternative
discrete designs [4-40V ip] :
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/5224
Still new, claims just 680uA for no load inductor mode, and it can
select LDO mode, for ~40uA Iq (100mA pk).
Has Reset and Sync to top off the features....
I see it also has a snap-action on rising Vin, which is something
very few regulators do - benefit it is avoids brownout areas, and
many devices have poor brownout behaviour.
-jg
rickman
Jim said:
John said:
Rick,
Thanks for the pointer. It would have been perfect, but the sync is
only good up to 500 kHz and we need 600 kHz. But this is exactly the
type of part I would like to have.
U
Uwe Bonnes
Sync it to 600khz/2!
Jim Granville
Interleaving two, out of phase, to get your 600KHz.
Efficiency vs: Load Current graph in the bottom right corner of pg. 6
shows only ~50% efficiency @ 10 mA, rising to 75% @ 14V input and
100mA. (http://datasheets.maxim-ic.com/en/ds/MAX5096-MAX5097.pdf)
Yes, something seems not consistent in their data.
They state 14Vin 5V out, Io=0, typ 680uA (9.52mW)
But then show 62% on the graph for 14V/5V/10mA, [50mW],
which suggests 30.6mW of losses. (2.2mA?)
Pity they don't plot Iq vs Io for BUCK mode.
-jg
That is a little puzzling, until you notice the buck mode Iq (they
call
it Is) spec at the top of pg.3 shows 720uA typ. for the 330KHz version,voltage Vadj is specified to be 1.4v--higher than the 1.2v reference
voltage.
Sneaky.
The problem is that banging those FETs at 330KHz is going to burn
some gate drive, which is why everyone likes to pulse-skip at low
powers.
Actually, I rather wonder whether this part might indeed start pulse
skipping at low loads, but I'm too lazy to check.
-jg
Regardless, efficiency-wise it beats an LDO by quite a bit, and for
all inputs.
Best,
James Arthur
Jim Granville
call
voltage.
Sneaky.
powers.
I've found a SMPS data sheet where they DO plot Iq vs Io, ( for a
LTC3835 ), and that does show a variation in loss, under 10mA.
On this device the losses corner is appx 0.5mA : below that, the loss
is effectively independant of Io, and above that, losses climb with io.
-so the maxim device might take 680uA at 0mA, and 2.2mA at 10mA Io.
Silly NOT to carry the graphs below 10mA, as someone might think they
have more wastage than they really do.
-jg
jasen
Thanks for the ideas.
Typically our devices have several power consumption levels. But I
can't use multiple PS circuits for better efficiency because they don't
make any that I have found that are efficient at low currents.
so don't use them at low currents. only enable them when you need high
current.
Bye.
Jasen
