Hitachi CM802U CRT monitor, Anyone know what IC I701 is?
Doug Warner
Photo here: http://webpages.charter.net/dwarner2/I701.jpg
Part of: Hitachi 21" monitor, model CM802U Manufactured June 1997
Issue: Heavy vertical jitter for about 30 seconds during warm up,
even after blank screen screen saver.
Designation: I701,
Markings: LA7860, 7BBS (no logo.)
Identified it by selective cooling with compressed air, general areas,
then through a couple feet of thin shrink tubing, then by dabbing with
a swab soaked in freeze spray. screen shakes when the chip passes
through a certain temperature range.
1. Is this a common part, or some Hitachi ASIC?
2. If I somehow managed to find a Hitachi servicer, would they replace
the part, or the whole board (assuming they're still available.)?
Yes, I could just buy a LCD display, but, to get the same real estate
of my two 21" CRT's, I'd have to buy an (expensive) 30" widescreen,
like the Dell 3007WFP..
DaveM
Designation: I701,
Email reply: please remove one letter from each side of "@"
Spammers are Scammers. Exterminate them.
You can get one at http://www.ceitron.com/semi/semi.phtml?part=LA7860. Don't
remember if they have a minimum order.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
Life is like a roll of toilet paper; the closer to the end, the faster it goes.
PeterD
Designation: I701,
Didn't even bother to Google this did you?
http://www.datasheetcatalog.com/datasheets_pdf/L/A/7/8/LA7860.shtml
on the *first* Google hit.
Doug Warner
Nope.. I was dead tired, and just plain forgot.
Searched the next day, found the datasheet, (Deflection generator -
fits the symptom) Found a dealer, ordered one.
Also found a place to order a service manual (poor PDF scan for $15.00
with zero disassembly info.
Guess I'll have to dredge up my old TV repair skills,
(Yes, I know how to discharge a CRT, and attach a clip lead to the
2nd anode connection to keep the charge from rebuilding..)
