N
N.O.Y.B.
- Jan 1, 1970
- 0
I have a Yamaha RX-V450 amplifier and it's plugged into what is supposed to
be a good quality surge protection power-board (a Belkin brand board with 10
sockets - the first 4 of the outlets are protected the remaining 6 are not,
but I made sure I plugged the amplifier into one of the protected sockets).
Now, this is where things are funny - I believe this board is supposed to
protect against voltage spikes.
My amplifier/reciever has digital input (PCM/Wave SPDIF/OUT) from the
high-quality (M-Audio Delta 2496) soundcard installed in my PC. I use
standard PCM input (digital wave-out).
When I'm playing audio the PCM indicator is on which indicates that digital
audio/wave is coming through as it should.
When I switch lights on/off the PCM signal is dropped for about a second and
then comes back, when this happens the PCM indictator on my amplifier goes
off and then comes back on to indicate the dropped signal. The same thing
happens when my refrigerator's thermostat switches on/off or when I use my
foot massager (which has an electric motor).
I suspect voltage spikes which may (or may not) be harmless - but it is
definately caused by switching. Is there anything I can do to prevent this
from happening in the future as I am concerned about the possibility of the
glitches causing serious damage to my amplifier and PC/soundcard hardware.
Worried,
Ben
Worried,
Ben
