Hi There,
I am working with a MCU STM32F405VET for any particular purpose. Lets say at this time firmware code has burn on MCU. Lets talk about HW issue.
Take a look the datasheet here https://www.qdatasheet.com/datasheet-download/190671/1/ST-Microelectronics/STM32F405VET6
In my design portion a 25MHz oscillator supports MCU for clocking. See the attached file.
In this time a watched dog ic STWD100NXWY3F working externally,https://www.st.com/resource/en/datasheet/stwd100.pdf
What it does is watchdog timer is as a system monitor to detect and reset an "out of control" microprocessor. When program execution goes awry it will not properly execute the code that restarts the watchdog. In such a case the watchdog timer will timeout and cause a microcontroller reset. In a properly designed system, the reset will correct the error. Is the case of independent watched dog from main MCU timer.
I want to connect a toggle switch in 2 and 3 point of crystal oscillator XT1 and wish to see the input out put of 1 and 4 of U29 watched dog.
No if you look on the circuit diagram, at U29 IC pull up and pull down resistor are visible.
Now according to datasheet of STWD100NXWY3F , EN-PIN should have pull down resistor should be 62-100k.
What I did is I have change R101 to 51k, then my board does not work.
If I remove it along with R106 then WDO is unstable but after a time MCU is going to RESET!
I did see in oscillator when I push the switch meaning that 3 and 2 pin of XT1 has been shorted then input of U29 distorted but wont disappeared.
It wont clear instantly , what do you think?
Datasheet of STWD100NXWY3F says, While the system is operating correctly, it periodically toggles the watchdog input, WDI. If the system fails, the watchdog timer is not reset, a system alert is generated and the watchdog output, WDO , is asserted. BUT MY MCU NEVER GOES TO RESET.
Now there is 2 way to reset this MCU.
Inactivated Q15 and Q19 coupled transistor those are use in F/W WD reset. or only drive Q16 and 18. A forward diode can activate them, for toggling crystal switch MCU can go RESET, but its questionable since application display is not clear
