How to control 12vdc relay with microcontroller!
No, you will need to use the arduino's output to drive a transistor and use that to switch the relay current. You will also need a diode across the relay contacts to protect the transistor.
This lays it out really well.
GreenGiant
Feb 9, 2012
842
where would we attach the external power supply in your diagram? also would a 3906 transistor suffice.
The external power would connect to Relay Power V+
That transistor would work, but be cautious it is only rated for up to 300mA so without a current limiting resistor you run the risk of burning it out
