How to make antenna for a Weather Radio
I got a Midland WR-100 weather radio. Because I live in a metal sided
house, the reception is poor. On the back there is a RCA jack for
external antenna. I can easily make up a piece of coax with a RCA
jack on the end, but what should I use for an antenna. I'd prefer to
make something simple out of wire, such a a straight piece of wire or
dipole type wire, strung under the roof of my deck, or a piece of
stiff wire pointing upward. I do have some old CB car antennas that I
could modify too, and mount them on the deck or rain gutter. I know I
could likely buy something, but I'd like to keep the cost down. I'm
not needing to boost the signal as much as to just get the signal from
the outside into the house due to the metal siding.
Simple and cheap are what I want.
And redardless of that I use, can I use common TV antenna type coax,
or do I need the stuff that was used for CB radios. (I dont recall
the numbers used on them, but know they were not the same).
Thanks in advance.
Geoffrey S. Mendelson
external antenna.
Use RG-6 (TV coax). If you have any left over, you can make a large (12")
loop out of it, anywhere along the way, so you might as well get a length
already cut with connectors attached. The connectors will be "F" connectors
for TV's etc.
Buy an F to RCA adaptor, but I doubt that it's an RCA connector. It's probably
a MOTOROLA connector that looks like a long RCA one. A Motorola connector
will fit in (and stick out) of an RCA jack, but not vice versa.
My experience with places like radio shack is that you will have to buy
an F to UHF adapter and then a UHF to Motorola. Maybe not, ask. Radio Shack
has lots of motorola plugs and adaptors, but their web site is not indexed
well and I don't feel like paging through them all.
As for the antenna, you can buy one, or make a simple ground plane or
dipole antenna. For example, a simple dipole would be two 18 inch aluminum
tubes, separated with about an inch of plastic rod. Connect each side of
the coax to one rod, and stack them vertically. You can put plastic caps
on the ends of them to prevent water getting in, but don't paint them.
You can play around with the location, orientation (horizontal or vertical)
and direction of the antenna for best results.
Geoff.
Phil Allison
** Use an indoor TV antenna - the kind with a pair of telescopic rods for
VHF reception.
Spread the rods wide apart and set each to about 18 inches long - get an
extension antenna lead if you need to and an adaptor for the plug to go to
RCA.
Should all be fine if kept out of the rain.
..... Phil
Michael said:
It is 50 ohm, not 75.
Doesn't matter. RG-6 has taken over the low end coax market, it's well made,
cheap, easy to find and can be gotten in regular, direct burial and
long distance hanging (with attched steel wire) versions.
For reception, the difference in impedance is meaningless and many hams are
using it for transmitting. Most hams use it for transmitters of 100 watts or
less, but some have reported using it for 500. (ouch).
It is a RCA/Phono connector. I have the same unit. Use the right
connector if you want good reception. You can see it in the photo of
the rear panel on page 5.
That's a lot easier. I have RG-6 compression RCA connectors. Strip the
coax with simple tool, trim the center conductor and squeeze. I bought
50 of them off of ebay including the compression tool for $50.
F to RCA adapators are easy to get an cheap.
A VHF ground plane cut for 162.475 MHz will cover the VHF frequencies
used by NOAA: 162.40, 162.425, 162.45, 162.475, 162.50, 162.525, 162.55
MHz
There is a sketch on the NOAA website showing the proper dimensions:
http://www.erh.noaa.gov/cae/images/antenna.gif
Ground planes are more difficult to make, he asked for cheap and simple
and a dipole will do it. Almost anything from 15 to 20 inches a leg
will do. I picked 18 as it's a foot and half and simple to measure and make.
Making it out of tubing instead of wire makes broadband enough that it will
cover all of his VHF scanning needs.
Two meter ham band antennas, of which I've made many, need to be 19 inches,
so 18 is close enough for 162mHz, and is simple. If the person building
it buys 3 feet of tubing, and cuts it in half, it will work well.
The NOAA transmitters use vertical polarization.
Good to konw, and it probably will be what he needs, but he may have
reflections, hills, buildings, etc in the way so it always is better to
try than not.
Geoff.
