How to make, where to buy, order 5 kHz, 10 kHz, 15 kHz crystal/ ceramic resonators
Don Lancaster
This guy came close , quartz ring, not a frisbee, but close :
http://www.btinternet.com/~time.lord/QuartzRings.html
Steve Roberts
Statek used to be the original source for tuning fork style crystals,
which is what you need at low kilohertz frequencies.
http://www.statek.com/
Many thanks,
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
la-la
thanks whit3rd.
Tuning fork is exactly what I need but still as an electronic
component.
Is it possible to place an order for a specified frequency tuned tuning
fork
or retune, fine retune one already manufactured.
Is machining, laser burning a good way to retune one tuning work to a
preferred frequency ?
Clock resonators are quite small (built as tuning forks).
Does it mean I can expect 5Khz, 10Khz, 15Khz tuning fork to be of the
like size ?
And is it feasible to place an order for a sample of pretuned kHz
tuning forks with one company, lab or a private person and them
manufactured and develivered at a reasonable price and in foreseeable
future ?
Thanks once again for your kind input.
Gerald Bonnstetter
Robert said:
32.768 kHz is 2^15 Hz
Where does 3.579545 MHz come from?
US TV color burst frequency. There is one crystal of that frequency in
every US TV. So they are very common and cheap.
Not sure how long that will stay after HDTV takes over. I would think
it would still be needed for S-video and lower quality inputs from
legacy DVD's and VCRs.
Gerald Bonnstetter
Bonnsoft - Computer Programming and Software Repair
Ventura, Iowa, USA
[email protected]
http://showcase.netins.net/web/bonnsoft/
Eeyore
Michael A. Terrell said:
So, if I need a 4 MHz clock for a CPU, I should scrap it and make it a
lot more complex to use a color burst crystal? How about those 10- MHz
frequency standards? Show me a SIMPLE design for a TCXO to proved a low
distortion 10 MHz signal from a 3.5795454545 crystal. Yes, i know that
it can be done, but why? There are dozens of common, off the shelf
crystal frequencies that are dirt cheap.
In reality TV crystals are no cheaper than other popular frequencies.
I've normally used 4, 8, 12 and 16 MHz for my microcontoller designs and there
have been no problems either sourcing them or with the price.
Graham
Michael A. Terrell
Graham
If you only need one or two, you can usually pull a crystal or two
from a jun TV set for free. I probably have 100 on hand from dead TV
sets.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Eeyore
sets.
I don't build stuff with salvaged parts though.
Graham
la-la said:
thanks whit3rd.
component.
fork
like size ?
future ?
time you told us why you want one of this freq. Without that, who knows
what options are most suitable. App, quantity, tolerance and so on.
NT
Michael A. Terrell
Graham
I will use them for prototypes, or to repair my personal equipment.
The failure rate on crystals is so low that it doesn't make sense to buy
a new part, when I have something on hand that is likely to outlast the
equipment.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
la-la
Ok.
Nothing special. Just testing wireless power/energy transfer, following
Tesla's ideas and one developed recently at MIT.
I am testing acoustic frequencies at first.
Michael A. Terrell
la-la said:
Ok.
Why do you need crystals? A tunable audio generator, of function
generator would work well at those frequencies.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Bob Masta
Ok.
Since this is just a test, and since you are using audio
frequencies, why not just use a standard audio function
generator? If you really need a stable audio frequency,
you might want to check out my DaqGen freeware.
It generates audio frequency waveforms with your
Windows soundcard. Frequency stability is excellent
since it derives from the crystal in the sound card.
And unlike a homebrew circuit, you can get low-distortion
sine waves, or just about any other waveshape you can
imagine. Then if your experiments uncover anything
worth following up, you can always build a dedicated
circuit when you know just what the ideal parameters are.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
Al
Hi Michael, this is completely off topic, but I have beeen trying to send
an order to you over two weeks...is your email working..I am the guy from
Australia.
Jan Panteltje
What's wrong with 4.433618 MHz ?
Graham
In fact most analog PAL TVs will have a 8.86 MHz xtal.
Makes it easier to get 90 degrees.
As for the OP remark, makes no sense.
If you want a one second tick, and for example have a FPGA on board,
it is one line of verilog from a 50MHz xtal.
Not much more lines of ASM in a PIC with a 20 MHz xtal.
Depending on how much jitter is allowed you can make a nice synthesiser
too in FPGA for many frequencies (higher the xtal too).
And finally the color subcarrier... will likely not be needed much longer,
its is all going digital, or at least Y Cr Cb, not composite.
Tim Shoppa
la-la said:
how to make a crystal /ceramic oscilator for a specicfied frequency in
kHz range ?
Is it posssible to make one on myself, or find someone to make it ?
What is a minimum order quantity for a crystal/c eramic resonator for a
specified frequency (kHz) ?
Please help me.
Many useful frequencies from 20kHz on up are standard stock items at
digikey. Less than a dollar for a standard value.
Custom ordering one is possible, but will typically be $100+ or so and
will have a turnaround time measured in a week or two.
If you just want a square-wave oscillator there are many techniques
(including user-programmable or distributor-programmable oscillator
modules) that may do the job depending on your phase noise/jitter
requirements.
If you want a sine wave oscillator there are numerically programmed
direct digital synthesizers for a few bucks that do well for many (but
not all) applications.
Tim.
