How to measure voltage produced by magnets
hizuka007
May 15, 2014
13
im just wondering because the method shown by steve and davenn should have the same effects as mine. here
with maximized effect (i think) because it is circular and the magnet spin at the center.. or maybe its because the two magnets are facing north on the coil ?
Don't you love it when a poster continues to prove himself wrong, but insists on doing it his way instead of following advice from people who actually know something?
14,486
Hizuka007
Are you going to try the suggestions you have been given?
or are we just wasting our time trying to help you ?
cheers
Hizuka007,
The reason your method doesn't work is because, with the magnet outside the coil, what tends to happen is that the changes in the magnetic field try to force the electrons in a single direction. Because the wire on opposite sides of the coil is essentially going in opposite directions, the small voltage induced in each segment of wire is cancelled out by the small voltage induced in the other side of the coil.
From the perspective of an electron that wants to travel one way along the wire, on one side the lines of force cross from the left, and on the other from the right.
If the magnet is inside the coil, those lines of force cross from the center to the outside of the coil. So looking from the perspective of the electron inside the wire, the lines of force all cross the same way. This means the small voltage induced in one segment of wire reinforces and adds to the small voltage induces in the next segment of wire, and so on.
You can do the same thing with a magnet outside a coil, but you would require a toroidal magnet (think donut or even a tube) that had the north pole on one face and the south pole on the other. You would then slide this up and down over the coil.
At the moment you're doing exactly not what we say, and while it may seem the same to you, it's a bit like we're telling you to press on the accelerator and you complaining that you've pushed the brake as hard as you can and the car's still not moving. Even if you can't figure the difference between the brake and the accelerator, we can.
hizuka007
May 15, 2014
13
Hizuka007,
thank you very much for your explanation sir,.
i think i need to study the mechanics of magnetic fields .
@davenn, sorry if i didnt do the suggestions mentioned above, because i see it as if it is the same mechanics as mine but i im wrong,..i didnt fully understand the mechanics of magnetic fields thats why i didnt absorbed the suggestions.
14,486
no Problems :)
make a new coil wind it around the outside of a tube as was shown and try again
cheers
