chatenever
- Aug 10, 2014
- 2
- Joined
- Aug 10, 2014
- Messages
- 2
Hello all. This is my first post on this forum. My kitchen has recessed lighting fixtures with four-pin fluorescent bulbs. One is not working. Swapped bulbs with one of the working fixtures to eliminate the bulb as the problem. I then measured voltage between each pair of pins in the receptacle (six measurements in all) and got zero voltage on each. I didn't know what voltage I should be reading, so I checked the receptacle on one of the working fixtures. I got the same zero volts!! How can these bulbs work if I'm reading zero volts at the receptacle??? I tried various voltage ranges on my VOM, including AC and DC.
There is no separate ballast on these fixtures. The ballast is built into the light bulb. Any ideas how I should proceed?
