How to replace battery
m35603
We have a ADT PC5508z alarm system installed in our house. It is not
active (i.e., we don't have a contract with ADT) right now. Two days
ago, the thing started beeping every few seconds, and by looking
through the manual, I figured out that it was a low battery warning.
Where in the world is the battery on this thing though? We took the
keypad off and there doesn't appear to be a battery in it anywhere. The
manual talks about replacing the battery every three years or so, but
nowhere can I find anything that tells me where the battery is located.
I would appreciate any help I can get. I dont' want to call ADT because
we haven't had one in the last two years, so they probably wouldn't
want to help us.
Thank you very much!
Angie
Crash Gordon
That's just the keypad, look for the main box...usually in a closet
somewhere. In the main box you will find either a 12v 7amphour sealed
lead-acid battery or knowing ADT it will be a 12v 3amphour sealed lead acid
battery. Find box, go buy new battery and replace it.
| want to help us.
| Angie
m35603
Well, duh, no wonder we couldn't find a battery in the keypad if the
battery is in the main box. LOL! Would be nice if they'd put this in
the manual for us uneducated ones.
Thanks so much!
Angie
Matt Ion
That's normally info you'd find in the installer's manual... they've probably
only left behind a user's manual.
Why would they want you replacing the battery youself, when they can charge you
a small fortune for a service call to come out and do a 10-minute job?
Crash Gordon
Probably because the alarm company usually services the system. The
batteries are not easily available, you have to buy them from a specialty
battery store (Batteries Batteries, Battery Patrol, Batteries R Us..blah
blah blah) - or online. Besides alarm systems should be serviced every year
are so by an alarm tech and one of those service calls would also include
changing the battery (which only last 3-5 years).
And DON'T just throw the old battery in the garbage, it contains lead -
please dispose of it properly.
DO clip off the terminals of the old battery to prevent shorting and
starting a fire.
Yer welcome...and be careful
Oh yeah...write the DATE you changed the battery on the battery with a
Sharpie and plan on replacing it again in 3-4 years.
| Thanks so much!
| Angie
acid
The
located.
because
| > | want to help us.
| > | Angie
Crash Gordon
Not everyone charges a small fortune to change the battery. For monitored
clients I only charge 35 bucks plus tax to change the battery...no service
call or trip charge. If they want a system checkup while I'm there then I'd
charge more...but not for just a battery call.
For local clients?,,, Yah...they gots to pay for service call + battery,
since we do have to make money somehow.
probably
charge you
Robert L Bass
usually services the system...
Battery replacement doesn't require any special skill. There's no reason why the homeowner shouldn't do it himself.
The batteries are not easily available...
I disagree. Hundreds of online stores carry them. Also, numerous retail outlets even sell them.
every year are so by an alarm tech and
years).
Smoke detectors need cleaning at least annually. Motion detectors are normally left alone unless they cause a problem. As state,
batteries usually need replacement every 3-5 years. Magnetic contacts protecting doors and windows are normally service-free unless
there's a lightning hit.
Smokes are easy to clean. Homeowners can clean one in a few minutes.
Good advice. In most commun ities you simply notify the trash collection company that you have a battery for disposal. They'll
pick it up on the assigned day for "haz mat" removal.
to prevent shorting and starting a fire.
Yep. It's also a good idea to wrap a couple of turns of electrical tape after clipping the terminals.
the battery on the battery with a Sharpie
Also excellent advice.
Regards,
Robert L Bass
Bass Home Electronics
941-866-1100
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Robert L Bass
call or trip charge...
That sets you apart from most alarm companies though. Most do charge a trip fee. People often call my online store to ask if they
can replace their own alarm battery. The most common reason given for DIYing it is, "My alarm company wants over $100 just to come
out and change the battery." Considering the most popular batteries wholesale for less than $15, that does seem a bit high.
BTW, I used batteries as a great way to make customers happy when there were blackouts in our area. After one particularly bad ice
storm we had numerous of customers with dead batteries. I went down to ADI and picked up a few cases of Yuasa NP712's and made the
rounds, dropping off replacement batteries and check systems for dozens of customers as soon as power was restored. I charged only
for the batteries; no service call fee.
Within weeks after that storm was over we were swamped with new referral calls of customers' neighbors wanting an alarm system.
After that, any time there was a prolonged outage I did the same thing.
I'm there then I'd charge more...but
not for just a battery call...
Well, you're being exceptionally nice. Most alarm companies charge a lot more.
Regards,
Robert L Bass
941-866-1100
F
Frank Olson
We have an annual "inspection clause" in our contract. If the customer
decides to exercise it, the battery's replaced free of charge. The
annual inspection adds $40.00 to the annual monitoring charge.
Don
decides to exercise it, the battery's replaced free of charge. The annual
even if it still tests good?
Crash Gordon
Excellent idea!
monitored
service
I'd
Crash Gordon
I am different...I do everything to keep monitored clients happy, after all
they are putting food on me table.
BUT...local client pay for any/all service and at a higher hourly than
monitored clients.
more.
| Regards,
| Robert L Bass
| 941-866-1100
Crash Gordon
A 3 year old battery may test good today, but not next week. I replace them
at 3 years, based upon my experience over the years that's what I get out of
a battery.
message
monitored
| >> service call or trip charge. If they want a system checkup while I'm
| >> there then I'd charge more...but not for just a battery call.
battery,
annual
Crash Gordon
I didn't say it did..only that the alarmco usually services them on routine
(or emergency) service calls.
Online is not exactly "easily" or readily available when the alarm panel is
squealling in trouble at 4am.
| > years).
I can see my 87 year old dad getting on a ladder to clean a smoke detector
then freeing out when it goes into trouble.
I bring them to my friend who owns a car service center, he just puts them
in the stack of batteries that Interstate picks up monthly.
Yep...I'm full of it! (Excellent advice that is:))))
Happy New Year!
| Regards,
| Robert L Bass
| 941-866-1100
Petem
Is it me or battery life is shorter then it used to be?
If my memory serve me right,they used to last like 5 years,some even more...
Crash Gordon
Shorter for sure.
Either the panel's charging circuits are rougher on the batts or the batts
are shittier...or combo of both.
With old Radx 6112's and Yuasa 12-7's I used to get 5 or more years, now
I'm getting 3 (and I mean almost to the DAY) out of them.
more...
| "Crash Gordon" <[email protected]> a écrit dans le message
de
| [email protected]...
them
out
| > of
| > a battery.
| > message
| > monitored
I'm
| > battery,
| > customer
| > annual
