How to replace battery
Petem
Makes no difference whether it's the 200 or the 300. They both "eat"
batteries (even the better quality ones like SOTA).
The 200 yup,and the worst is that they dont even supervise the battery..
but on the 300,i dont have this problem...
We've got three jobs "in the mill" (that we've bid on) using Kantech's
newest "widget" but I still have some reservations considering all the
problems we've experienced with "new widgets" from DSC and Ademco in the
past.
Have you been dealing with Kantech since long?
Been dealing with them when they were still called Omnitron...only a few
employee of the company knows that it was called like that...
and usually they make a very good testing of there stuff before releasing to
the mass,I was a beta tester for them on the Entrapass Global product
version 1(was called KL9000 in those days and after entrapass NT) and they
were even releasing beta stuff that were not too bad..
I have a KT ncc in the truck right now,since I go back to work only on the
8th I will be playing with it in the next few days...I want to make it crash
and do things its not supposed to,just to test it a bit....
Tommy
Robert, You claim to have spent all those years doing this work. You know
that what he has posted is not unreasonable. the cost of a battery plus a
service call. Any of the heavy hitters would be higher than that. I am like
a lot of others here and use battery changes as a good way to garner good
press and good feelings from my customers, but I do charge a service call,
or charge them for the battery but not usually both.
Needless to say, this is for monitored customers. All others fall under the
"gas, ass, or grass, no one rides for free" column.
Robert L Bass
years doing this work. You know that what
cost of a battery plus a service call. Any
that. I am like a lot of others here and use
good press and good feelings from my
customers, but I do charge a service call, or charge them for the battery but not usually
both...
That's good customer relations. You probably get more value in referrals and "good will" than you could by nailing the customer at
every turn like some of these idiots.
customers. All others fall under the "gas, ass, or grass, no one rides for free"
column.
Other than online dealers like myself, almost everyone has different policies / prices for monitored and non-monitored accounts.
It's been a while since I heard anyone use that old hitch-hiker's lament though. It reminded me of something I used to do when
hitching home from Boston to NJ every few weekends. I'd stand by the entrance ramp to the Mass Pike. When I saw a pretty girl
passing I'd start a conversation to get her to stand next to me while I held up my NJ sign. Sure enough, within a minute or two
someone would pull over. Those were the days... :^)
Regards,
Robert L Bass
Bass Home Electronics
941-866-1100
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Tommy
though. It reminded me of something I used to do when hitching home from
Mass Pike. When I saw a pretty girl passing I'd start a conversation to
within a minute or two someone would pull over. Those were the days...
Try that now, and you'd end up with a sexual harrassment lawsuit, or chopped
into pieces by some road ragin' wacko. maybe both.
Doug
I prefer to charge what my services are worth, you obviously charge what
your services are worth.
Doug
Jim
past.
I use JIMs LAW:
No new product will be used before it's one year anniversary.
Julian
Battery replacement doesn't require any special skill. There's no reason why the homeowner shouldn't do it himself.
Oh REALLY? Ever change a battery on an old DSC Classic Panel? Ever
checking the charging voltage? Pretty obvious you haven't.
DSC's charging circuit can be varied in voltage from approximately
12.5 to 14+ volts. Should be at 13.8, but over time it will wander.
I've seen over 14 volts and as low as 13. If the voltage is high, the
battery life will be less, significantly less. If it's low, then it's
not getting a proper charge and will last a shorter time when power
goes out.
How's that for reason #1?
Reason #2?
MOST clients are idiots and will not be able to do it or will do
something wrong.
I disagree. Hundreds of online stores carry them. Also, numerous retail outlets even sell them.
Smoke detectors need cleaning at least annually. Motion detectors are normally left alone unless they cause a problem. As state,
batteries usually need replacement every 3-5 years. Magnetic contacts protecting doors and windows are normally service-free unless
there's a lightning hit.
Smokes are easy to clean. Homeowners can clean one in a few minutes.
Sure, I LOVE to have homeowners clean their own smoke detectors! I
guarantee they didn't listen to the instructions and will BLOW air
into the detector instead of SUCKING THE AIR (AND DEBRIS/DUST) OUT.
I sell more smoke detectors that way....... AND I CHARGE A FRIGGIN'
SERVICE CALL TOO!
And I'm seriously considering and IDIOT charge, although I will have
to remame it.
Perhaps I'll call it the bASS charge!
LOL!!!!
Good advice. In most commun ities you simply notify the trash collection company that you have a battery for disposal. They'll
pick it up on the assigned day for "haz mat" removal.
Yep. It's also a good idea to wrap a couple of turns of electrical tape after clipping the terminals.
'Cause you just know a dead battery without terminals starts an
electrical fire every 16 seconds in the US.......
Also excellent advice.
Julian
Robert L Bass
a sexual harrassment lawsuit, or chopped into pieces by some road ragin' wacko.
maybe both.
Yeah, things have changed. Years later when I had my own car I used to give rides to hitch-hikers -- sort of returning the favors I
received. Now, unfortunately, it's just too dangerous. I guess most people have the same impression, too, since you rarely see
hitch-hikers any more.
Regards,
Robert L Bass
941-866-1100
Robert L Bass
worth, you obviously charge what your
services are worth.
You apparently charge as much as you can get away with. I don't service alarms any more. I'm just a phone clerk like your idiot
pal from Burnaby.
Robert L Bass
on an old DSC Classic Panel?...
Nope. Then again, I never installed an old SDSC "Classic" panel.
Ever checking the charging voltage?
Pretty obvious you haven't...
Well, you're wrong. I used to check the charging voltage on Napco and Moose systems. Every once in a while one of them would be
off kilter but that would almost invariably be indicated by other problems.
in voltage from approximately 12.5 to
time it will wander. I've seen over 14
is high, the battery life will be less,
significantly less...
I usually ask clients who call about replacement batteries how long it's been since the old one was installed. If it's been less
than 4 years or so, I ask if there's been an extended power outage. Most of the time they say the battery was installed by the
"professional" installer and has never been replaced since. Many times the client says that the system -- and the battery -- have
been there for 8, 10 or more years.
Inadequate.
Reason #2?
be able to do it or will do something
wrong.
If that is the measure of the typical person who hires you, I can understand your concern. If this newsgroup is any indication of
things in general, I'd say the *avarage* DIYer is smarter than the *average* professional installer.
AT any rate, changing out a backup battery is a 2-minute affair. That includes time spent looking for the key to open the cabinet.
their own smoke detectors! I guarantee
will BLOW air into the detector instead of
OUT.
Do you always suck or do you also blow from time to time?
OK, sorry. That was rude.
AND I CHARGE A FRIGGIN' SERVICE
CALL TOO!
All kidding aside, I'm curious where you learned to "clean" smoke detectors that way. I always open the cover and clean the entire
interior with a moist (not wet) cloth. Then I open the sensing chamber and clean the inside with an alcohol swab. I find this is
much more effective than using forced air. The smokes will often last much longer between cleanings.
charge, although I will have to remame it.
Hmm. Do you write "idiot" in bold print on your stationery?
without terminals starts an electrical
First of all, my inexperienced friend, the battery isn't "dead" or it would not be necessary to clip the terminals. Anyone with
experience in the trade instead of clerking and swapping aliases all day knows that.
Second, even with the terminals clipped off, the electrodes are still reachable. In the unlikely event that something metallic iin
the trash were to come into contact with them, a fire could result. It takes less than 10 seconds to wrap a little tape around the
battery to completely prevent that. But you wouldn't know that, would you?
Regards,
Robert L Bass
941-866-1100
F
Frank Olson
Robert said:
... a phone clerk like your idiot
pal from Burnaby.
Minor addendum in my case: *licensed* "phone clerk".
Julian
Figures.
So then do you get your 'customers' to check and adjust the charging
voltage? It may not require any special skill, but it certainly
requires knowledge and experience.
So you have the cheap, lazy clients who won't change their battery as
required. An eight year old battery is of little use - other than as
an anchor - and is far past its' servicable life.
It's doubtful that a customer like that would produce any tangible
profit UNLESS they're charged FULL PRICE for the battery and the
service call. AND any alarm panel that is that old and unmaintained
NEEDS an EXPERINCED ALARM TECH to properly service the system. I would
never monitor an alarm system that is that badly maintained.
Inadequate.
Hey quit looking in the mirror and focus!
I don't pick my customers based on their IQ, only their ability to
afford my services. The average DIYer may be smarter than you, but
certainly not smarter than any professional installer I've ever met.
Then again, I've never met you..... Oh, right that doesn't matter -
you're not a professional installer. You only run an internet store.
Nothing to do with installing or servicing alarms or monitoring
Florida customers.
And what am I supposed to do about the 1/2 hour to go over the alarm
use/features/coverage? If my client wants to have me over to change a
battery, move a motion, program a code or have me over for coffee and
cake, my hourly rate is the same. More time is wasted going over
things over and over again due to the short term attention span of the
client. Not to mention, most people's inability to answer a simple
question with an answer that matches the question, not an answer to a
question that wasn't asked. GOT IT?
Hint: Simple YES or NO.
ALL clients with smoke detectors are give the same instructions - use
the dust attachment of the vacuum and clean the unit every three
months. No disassembly required. If any client was to do that, then
the units would function for a longer period of time.
My method is to clean the interior of smokes, but c'mon - who the hell
carries alcohol swabs for cleaning the sensing chamber? Another tall
story I guess.
And wouldn't cleaning smoke detectors require a service call to the
premise? Gee, and I thought you only ran an internet store..... must
be the propoganda.....
Sorry it's only a line item charge and has nothing to do with the
stationery. I haven't even implemented the damn charge and I've
already had my first question about it. Seems the charge is justified
though.
Great now you owe me $25.00. I take CASH only BTW. Email me for the
snail mail address. Don't forget to put proper postage on the stamp.
Oh and seal the envelpe too. Drop it in the mail box is the last step.
I don't know if I'm more offended by you calling me your friend or
inexperienced, but I can guarantee I'm neither.
Anyone with
How exactly do I clerk an alias? You must know, you've been an alias
swapper for many years - on this NG and others - so you must have
clerked a couple too. I've used two aliases here in the past eleven
years. Yes, I've been here that long, albeit with a long absence
between then and now
OMG you are a MORON! So you want to prevent something that is unlikely
to happen and if it did something else could happen. I have more
confidence in winning the lottery next week to secure my retirement.
Just to prove you wrong, I'm going to take a recently changed battery,
leave the terminals on and try to start a fire. Or I could call the
Mythbusters, but the only myth here is your qualifications.
I'll let you know what my results are. At first I'll use the metal
only. Then I'll try metal and paper. Then metal, paper and an
accelerant, maybe alcohol swabs! And if that doesn't work I'll up the
ante to gasoline.
Hey this does sound like a Mythbusters episode. The cell phone blowing
up a gas station episode. I'll download it and let their judgement be
answer to the question.
Julian
Petem
Roland said:
Most of the over the counter stuff, be it from TOPAZ to Northern
Computers has its place, and that is in the dumpster in my opinion,
especially old Nothern stuff.
At least we do agree on something...NCI stuff is one of the worst stuff I
ever saw..a few years back,was at big facility and they were using winpak
told the boss I could open a door if I get access to the com link without
them knowing about it..
they didn't believe me,it took me 5 minute to set up my converter and
connect my laptop fire up hyper terminal and bypass the door status input
and fire up the relay,the door was open and no one saw nothing in there
log...
using plain simple ASCII command to control there system was the worst they
could do..that with the way they handle site code...
Robert L Bass
Indeed. I never liked that kind of cheap crap.
check and adjust the charging voltage?
it certainly requires knowledge and
experience.
I've instructed a few people to do it. It's about the simplest procedure there is, requiring neither skill, knowledge no
experience. However, if you find it challenging I can understand your concern.
required...
Actually, these are usually clients who relied for years on their professional installing dealer to maintain the system before
dropping the monitoring contract for whatever reason. The low battery warning is often the first indication that the system had not
been properly serviced, sometimes for years.
use...
So is an alarm company that doesn't bother to replace a battery for six or eight years until the client finally drops their service.
would produce any tangible profit
for the battery and the service call...
I'm not surprised that you think that. Fortunately for me, there are lots of end users who get fed up with that kind if trewatment
(not to mention that kind of attitude) and go searching the Internet for a new supplier. Just as Bob Campbell has made a good
living for years taking over accounts from one particular, well-known alarm company whose services are notoriously bad, I make a
nice living helping the people guys like you used to abuse.
and unmaintained NEEDS an
properly service the system...
These are usually ex-clients of "experienced" alarm techs who have ignored routine service requirements so long that only a good
DIYer can save the day. Most of the time when we get a DIYer who has taken over service after a "professional" alarm installer did
the initial job, it's because the "professional" dealer either screwed up the installation, failed to service it in a timely manner,
charged rip-off prices, failed to respond promptly to alarms or some combination of the above.
BTW, I'm not saying that all or even most alarm dealers do such bad work. I like to believe that this newsgroup is not
representative of the industry at large -- that most are actually intelligent, caring people rather than liars and frauds like
Olson, Cracker and the Matawan Moron (aka "Group Nutcase") or rip-off artists like a certain ECLA member, his Worthless pal and
Jiminex. I suspect most are more like Bob Campbell, Jim Rojas or (and this is one I only recently realized has a heart) Tom "Tank
Top" Fowler.
I would never monitor an alarm
Well then, we finally found something in common. :^)
IQ, only their ability to afford my services...
So you say your customers are stupid but at least they have enough money to buy what you sell? OK.
you, but certainly not smarter than any
professional installer I've ever met...
In your dreams, Bubba.
right that doesn't matter - you're not a
professional installer...
Not any more. I ran a central station alarm company for 24 years though. We were small so I kept a hand in installation and
service even after hiring techs. It was a fun way to make a living but I found something more lucrative that also affords me the
freedom to travel extensively, spending several months at a time at my second home in Brazil.
Florida customers.
Yup. However, I've spent more years installing and servicing alarms than you've been out of diapers (then again, perhaps that's not
saying much).
1/2 hour to go over the alarm use/features/coverage?
change a battery, move a motion, program
cake, my hourly rate is the same...
If he wants you to do all of those things, you probably ought to bid a flat rate rather than gouge him with your hourly rate. If
your clients are as stupid as you say they are, I guess you can keep getting away with it though.
More time is wasted going over things
term attention span of the client...
It's always the customer's fault, eh?
to answer a simple question with an
not an answer to a question that wasn't
asked. GOT IT?
Oh, that explains why you have so much trouble teaching them over and over and over and over again. Perhaps if you learn to answer
their questions properly they won't have so much trouble. Of course, if you taught them better, they might not need to call you
back for so many expensive service calls. Hmmm.
the same instructions...
Your clients give you the instructions? I thought you said they were all stupid.
- use the dust attachment of the vacuum
and clean the unit every three months. No
do that, then the units would function for a
Unfortunately, partical matter inside the sensing chamber is never completely dislodged by such a procedure. It will suck out big
dust "kittens" from inside the cover but it does nothing to clean the most critical part, which is the sensing chamber.
sensing chamber?...
I always did and my techs always did. It's really no trouble keeping a box of swabs and a small jar of alcohol in the van.
Another tall story I guess...
Anything you never thought of must seem so to you.
require a service call to the premise?...
I think you meant premises. One doesn't service a premise. AT any rate, no. It's easy to do that. Any DIYer can handle it.
However, I notice that you weren't even aware of the need. Did you say that you're a "professional" installer? Hmm.
internet store..... must be the propoganda.....
You thought wrong, grasshopper. I've been in this industry many years before there even was an Internet.
calling me your friend or inexperienced,
but I can guarantee I'm neither...
The "friend" part is a sarcastic expression. I prefer it to calling you an asshole. As to experience, you've already shown you
don't know how to clean a smoke detector or properly dispose of a used alarm battery. I think you've demonstrated your lack of
experience sufficiently.
You don't read very well either, do you?
Have you been taking debating lessons from Olson? I understand he's also offering PPSEL lessons, in between aerobatic airliner
antics.
OMG you are a MORON!...
Translation: You discovered you're wrong.
that is unlikely to happen...
We sell smoke detectors to detect fires, even though they may be unlikely to occur in any given location. It's called common sense.
happen...
Since that "something else" is a fire, yes.
I have more confidence in winning
retirement...
If what you post here is any indication of your skill as an alarm installer, perhaps that's a good investment plan.
start a fire...
Piece of cake. Shove a piece of wire into the small holes where the terminals used to be. Be sure to hold onto the wire nice and
tight while you practice this experiment. You'll have a nice reminder for the next few weeks what a stupid idea it was. After your
hand heals from the burns enough to type, be sure and post all about your experience.
Note to everyone else: "Professional driver on closed course. Do NOT try this trick at home."
Or I could call the Mythbusters, but
You think they'd actually talk to you?
No need. If you do this in the vicinity of a sufficiently large quantity of gasoline I'll be able to see the glow from here.
At first I'll use the metal only...
You're reminding me of the famous last words of a redneck: "Hey Bubba, watch this....."
paper and an accelerant, maybe alcohol
ante to gasoline.
All kidding aside, please don't. You're too entertaining to lose and I really don't wish you any harm.
Regards,
Robert L Bass
941-866-1100
Jim
Petem said:
"Jim" <[email protected]> a écrit dans le message de [email protected]...
That's a good law...
its a lot better then Roland's one
If its not an American produce,or one of there close allies its shit..
Coincidently, I'm testing a Canadian made product (which will remain
nameless)
right now.
I
I brive a dus
Julian typed:
story I guess.
Alcohol swabs and pads are a MUST (clean any surface before mounting
equipment)
Also make sure you have:
A handheld vacuum (don't be a piggy in someone else's home or business)
A dropcloth (lay your tools down on them)
latex gloves (to prevent marking walls)
dustpan and brush (more piggy prevention)
Drill Doctor (nothing worse than a dull bit)
and shaving cream (spray a tad over the spot you are drilling through
to prevent dust and catch any possible asbestos)
Robert L Bass
... shaving cream (spray a tad over
the spot you are drilling through to
asbestos)
Ok, that's one I never heard of before. Nice.
Regards,
Robert L Bass
941-866-1100
F
Frog
please do not throw old alarm batteries in the trash. take them to your
local auto parts store to be recycled. sheesh
