How to supply 5v at higher current?
adamq
Dec 17, 2013
78
Hey folks... I'm trying to find a solution to supply 5 volts at a minimum of 50 watts--more would be better. The caveat is that it must be no taller than 1.5 inches (goes inside a pre-existing enclosure).
Suggestions welcome :)
adamq
Dec 17, 2013
78
Ultimately, the power is coming from the mains (120v). The expected load is around 30 watts (5v @ 6A). I'd like room to grow, though, as I may add more load in the future. This is why I am looking for a 50w solution.
dorke
Jun 20, 2015
2,342
You will probably need a Switch-mode Power supply.
There are more details needed.
1.What is the noise level allowed on the 5V.
2.P.S regulation parameters (i.e. how stable is the 5v).
3.How is the heat from the P.S be dissipated
Will one of these do?
Edit:
They are about 30cm height,though that seller doesn't advertise it.
Need to contact him about that.
adamq
Dec 17, 2013
78
Sorry guys I'm not trying to be insulting by being secretive. I'm working on a new idea.
Dorke, I did see those and similar units while researching. They might be a good option. My worry is voltage drop / ripple / bad power generally. Part of the load is a microcontroller that is adversely affected by bad power.
What does everyone think about using a higher voltage switch-mode PS (say 12v) and several L78S05 in parallel? Does that make sense?
Or would I be better off filtering that 5v psu, say with some substantial caps/whateve else is needed.
cjdelphi
Oct 26, 2011
1,166
You can just filter the smp with a good capacitor for 5v supply, linear regulators will waste too much energy from a 12v source..
14,487
I doubt you are going to find a full PSU with your output requirements that will fit into your size requirements
it mite me time to reconsider your project limitations
adamq
Dec 17, 2013
78
OK. So maybe it's not figured out yet then. I'm certainly still open to suggestions.
Dorke: the board has its own 3.3 regulator, so 4.6v (5v @ 92%) is still sufficient there. Ripple & noise is what I'm most concerned about here.
I understand a substantial cap (bigger the better, yeah?) will filter out a lot of the ripple, but I'm less clear on how how to reduce noise.
adamq
Dec 17, 2013
78
OK I didn't know that. I understood ripple and noise to be two different things. I though ripple was repeating pulses from the power supply (like when rectifying AC to DC) as part of the waveform, and that noise was like random spikes here and there caused by the way switch mode PSU's work.
I understood why rectified AC produces ripples, but I didn't understand that noise is the same thing, this is just stuff I've read and am regurgitating.
Anyway....now that I know its the same thing, do you have any capacitor type/sizing recommendations? Am I wrong in thinking bigger is better in this case?
cjdelphi
Oct 26, 2011
1,166
Lots of reasons, but anything that affects the output, be switching, inductors, hum, either way it's unwanted stray voltage...
1000uf per amp i read somewhere, but i think it's a little much
dorke
Jun 20, 2015
2,342
Well you see,
You do need to totally specify the requirements of the P.S ,
otherwise the solution you will get to will be far from optimal in terms of cost/space/efficiency/reliability/performance etc.
So Lets start from the beginning,shall we?
1. What is it "driving"?
(as you now say,
the voltage is converted to 3.3V by a regulator,which one?,
any other like this?).
2. What is the min and max voltage swing allowed?
3. What is the current you need(min and max?
4 .What is the space you have for it (LxWxH).
5. What is the noise and ripple levels allowed?
6. Any safety regulations requirements?
7. Heat dissipation issues?
