robb
- Jan 1, 1970
- 0
Thanks Chris for the help and ideas,
robb
robb
robb
Thanks Chris for the help and ideas,Chris H said:Yes... Most will let you do this with a script.
Try uVision
I would agree.
The costs don't look small but if it is the only tool that will do the
job.....
The 80561 is far from obsolete. However is the OP is only going to do
this one 8051 project renting is a good idea.
OTOH if the OP wants to do a lot of 51 work buying a good one is a good
long term investment.
Costs depend on where you are and what you need. For 8051 the cables and
pods vary a lot depending on the target.
Not only the software but the facilities...
You need the ICE to be able to run at the bus speed of the target...
NOTE some 51's are *2, *3, *6 and *12 a standard 51.
You need trace & trace filtering, Also depending on how the trace
works the size of trace is important. Due to different methods a 2K
trace can be a effectively as big as an 8K trace
Trace should give C, ASM and raw (binary) trace.
conditional breakpoints etc
It goes without saying it should be non intrusive
You need both C and ASM debugging
system.
If you have a decent ICE you won't need the Logic Analyser.
And a lot of time and luck.
\/\/\/\/\ Chris Hills Staffs England /\/\/\/\/
/\/\/ [email protected] www.phaedsys.org \/\/\
robb
