I need help with a circuit
Jgberg
Oct 27, 2023
Would this IR circuit work for an Arduino? Are any more parts recommended or is it fine how it is? I've seen capacitors added to similar circuits, but not sure where those would be placed.
14,317
In principle yes - depending on what it is supposed to do.
Add a 1 µF or bigger capacitor between 5 V and GND. This will help to supply curent peaks when the LEDs are turned on.
You can improve the efficiency of the circuit considerably: Instead of using two IR-LEDs in parallel, put them in series. The voltage drop will increase from ~ 1.6 V to ~3.2 V, therefore reduce the series resistance accordingly. Like so:
You will then need only 4 transistors and the base current (drive current from the Arduino output) will be reduced accordingly. With 4 transistors you can increase the number of LEDs to 16 instead of the 14 you have now. Or use 14 LEDs, the last transistor will then drive only 2 LEDs, not 4.
Jgberg
Oct 27, 2023
Awesome, Thank you for the info! Would you by chance know if I would have to increase the ohm value and for a 16 LED circuit, would you by chance know the current draw? Would this circuit work on a 300mA supply?
Martaine2005
May 12, 2015
5,318
Use Ohms law to calculate the total current.
Or make the circuit and measure the total current.
But you have to specify what brightness you require therefore altering the mA to each LED.
You may find that 5mA is bright enough or 15mA etc.
Have a good read HERE to get a good understanding.
We use V for voltage so V=IxR whereas the formula from Fluke use E for voltage so E=IxR (same thing).
Martin
14,317
We have a resource on driving LEDs. Read all the info you need there.
When you add 2 LEDs in series, as I proposed, the voltage drop across the resistor is less than with a single LED. Therefore the resistance needs to be lower for the same current.
That's up to you. You define the current through the LEDs, then calculate the resistors accordingly, see the resource I linked.
In your circuit you have ILED = (5 V -1.6 V)/ 220 Ω = 15 mA (1.6 V being the typical voltage drop across an IR-LED).
With 2 LEDs in series the calculation goes: R = VR / ILED = (5 V - 2 × 1.6 V) / 15 mA = 120 Ω
bertus
3,877
IR leds may have different specs than standard leds.
There are IR leds that allow peak currents of 100 mA.
Read the datasheet of your IR led for a decent current.
Have a look at the attached VISHAY datasheets.
Bertus
  • VISHAY_TSUS5200_TSUS5201_TSUS5202.pdf
  • VISHAY_tsal7200.pdf
loadhead
Nov 27, 2023
28
It looks like possibly you want a fair bit of power here?
So you would external power it, not use the arduino power, and just run the transistors with the arduino out, then itll work for sure.
roughshawd
Jul 13, 2020
618
When you decide on the reason behind having all these LEDs, maybe you should add a dimmer and a terminator to the line so it doesn't do ump every thing to ground when you turn it on. They say diodes are a good choice, and functional circuits are important to stay in the loop.
mineymoe
Nov 14, 2023
18
Lots of great advice here from others! Definitely check the LED specs and do your calculations. With some tweaks to drive them properly it sounds like this could work for your project.
Alec_t
Jul 7, 2015
3,821
The post #1 set-up will draw about 30mA from the Arduino Data pin. Is that ok?
14,317
Is that ok?
It is not.
An Arduino can supply 20 mA continuously, 40 mA peak.
Here's where my scheme from post #2 comes in handy by reducing the current requirements from the Arduino's output pin by a factor of 2.
Kiwi
Jan 28, 2013
506
I may be missing something here, but it looks like all the transistors are in parallel from a single Arduino output pin?
Could you just use a single MOSFET to drive all the diodes?
