I Need Some Help With a Level Indicator Project
superjon
Apr 18, 2014
7
I was approached by a close friend of mine with an idea he wanted to know if I could help him with. He has a business that installs chain link fences for people. He has a Bobcat skidloader with a post hole auger/digger on the front. The post hole auger is very large and is raised up in the air and then lowered down to the ground and continually lowered as the auger winds into the ground creating a hole for a fence post. The auger motor and auger bit are very large and hang on a 2 axis pivot point so that it can be leveled by gravity. See the attached picture to help create a visual. The sensor assembly can be mounted on the side of the auger motor to get the best sense of the auger's actual position.
What I am looking to do is use possibly a multicopter flight controller or just a sensor board of some sort and feed that data into something like an Arduino board or an OSD board (like the multicopters use) to create a video output feed. Then, in the operator's cab of the skidloader, the operator will have a small LCD screen with a basic graphic displaying the actual position of the auger vs the actual position of true level with the earth. It does not need to be anything fancy.
A few of the design goals are:
-Simplicity and low cost
-The sensor assembly needs to be battery operated for simplicity
-The video feed needs to be wireless RF from the sensor assembly on the auger motor to the LCD display in the operator's station
-Prefer working with existing low cost components to keep things simple and affordable
I am sure there are questions that need to be asked so feel free to ask away and I will answer them as they come in. Thanks ahead of time for your help with this.
Jon
Arouse1973
Adam
Dec 18, 2013
5,178
Hi Jon
Would an simple character LCD work that displayed the X and Y values of a digital accelerometer. This is about as simple as I can think of.
Adam
Martaine2005
May 12, 2015
5,288
Being as we are talking "Big Boys Toys", I have a very low tech idea.....Cheap ish too...
Should be repeatable too, as the motor mount can't move.
Spend 10 minutes getting the auger bit dead level with a level...
Put a small self levelling lazer level in the cab.
Mark the cross levels on the back of motor housing facing the operator.
Well, I did say lo-tech!!:cool:
Martin
superjon
Apr 18, 2014
7
Martin
Martin,
You are the master of simplicity! Unfortunately that will not work in this application as there are various augers with various lengths and the terrain can vary such as hills and such. So having a fixed crosshairs that would always be at a different height.
As well, the side to side axis would be easy to shoot with a laser, but I don't think there would be a practical method to visualize the forward back tilting (Y Axis) for the driver to see.
It's still a very good idea, though.
Martaine2005
May 12, 2015
5,288
I will not go down without a fight!!!!
Drill a bigger hole and use a level on the post..:p:D
Nah, go with the μcontroller and join the "dark side"..
Martin
superjon
Apr 18, 2014
7
Hi Jon
Adam
Adam,
I think I understand what you mean by "displaying the X and Y values." Would the operator simply see two sets of numbers each representing the X and the Y axis and he would simply adjust the position of the auger until the numbers reached zero?
I guess my first thought is would there be angle be represented by a positive or negative number so the operator can determine which way he needs to adjust the auger position?
I think this could work, but I have to remember we are not dealing with a techno-savvy person that will be operating the equipment and using this sensor readout.
Jon
superjon
Apr 18, 2014
7
Martin
Martin,
By microcontroller, do you mean the one that Adam mentioned in the earlier post?
Also, I hear the dark side has cookies!
Arouse1973
Adam
Dec 18, 2013
5,178
Adam,
Jon
Yep you got it. You can display anything you want. "Left a bit, right a bit, too far numpty" :)
Arouse1973
Adam
Dec 18, 2013
5,178
What sort of accuracy are you after? If it's 1 degree or greater then you might not even have to calibrate the unit.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,984
I would get fancy and make the LCD display a two-axis bubble level. Center the bubble then auger away. Maybe communicate from the sensor mounted on the auger to the display in the cab with Bluetooth. How are you going to get power to the sensor? Battery operated? Tell me the brand so I can purchase stock in that company.:D
Martaine2005
May 12, 2015
5,288
Arduino
Martin,
Yes, the Arduino is a micro.
Are they chocolate chip? I could be tempted!!
Martin
hevans1944
Hop - AC8NS
Jun 21, 2012
4,984
If you have an Android smartphone laying around, with the Best Level app installed, you could build a little shelf and attach it to the auger with a mirror at a 45 degree angle to view the cellphone screen from inside the cab... maybe mount a cheap telescope in the cab for a better view, use Velcro to attach phone to shelf.
Martaine2005
May 12, 2015
5,288
Now I don't know if this is "Tongue in cheek", but it should be!!:p
Hop, that's worse than my idea....:D
Made me laugh though.... Mirrors at 45 degress?.....A shelf with velcro?......On a Bobcat?:p
What about power?
Martin
hevans1944
Hop - AC8NS
Jun 21, 2012
4,984
What about power?
Martin
Tongue in cheek? How absurd, you know I only give my best advice here.:cool: As for power,
I actually think my idea could work if the operator in the cab had keen vision and could see the smartphone screen without optical aid.
However, on second thought, it might require building a box around the phone and mirror to shade the LCD screen from ambient light. My phone LCD screen is virtually unusable outside in daylight conditions, and totally unusable if the sun is shining brightly. Sooo... I guess we are back to using a cheap, dedicated, battery-powered, MEMS accelerometer sensor with a wireless Bluetooth data link to an LCD "video" display in the cab. So much for simplicity and low cost. <sigh>
I actually have all the parts on hand needed to build this, except for the MEMS accelerometer, available for about three dollars from Sparkfun Electronics. That would be two Arduino Uno boards, two Bluetooth shields, and an LCD shield. Just add some software and... Voila! A remote level sensor you can strap onto the auger while working, and take home to play with after work. Plus it's a lot less expensive than even a used, second-hand, Samsung Galaxy 4 cell phone. I still think the velcro and mirror approach would be kewl though.
