Need help, level shifting
amdx
I have a 1 volt 5hz triangle wave setting on 4vdc, I need
to lower the 4vdc to 1vdc. (This is chip #1 output)
I'm driving pin 7 of a XR2206, you adjust frequency by sinking
between 1ua and 3ma from this pin. (This is chip #2 input)
Chip #1 is driving a 4.7k resitor with a 220kohm to ground.
Chip #2 Pin 7 is connected to the junction of the 4.7k and 220kohm.
I want to avoid a negative supply.
Thanks, Mike
Jim Thompson
Thanks, Mike
And what is chip #1?
Maybe post a schematic? A link, or on ABSE?
...Jim Thompson
amdx
...Jim Thompson
Chip #1 is also an XR2206 pin 2 is a triangle output.
Jim Thompson
Post a schematic if you want help. I don't have time to reconstruct
one from verbiage.
...Jim Thompson
amdx
one from verbiage.
...Jim Thompson
Thanks Jim,
I found a solution which led to better one.
Mike
