Identifying electrical component
dolev1986
Sep 7, 2015
Hi ,
i have a problem with my cars "board window switch". The main swich (automatic) is not working well (it stuck) , so
i open the device and i noticed 1 part that the swich connecting to it. I think the component is not good , i have 5 picture of the component , and i would like to know where can i buy it and what is the name of this component , so i can search it.
You can see at the picture that the "pin" stays right/left and not back to the middle. Thanks.
Minder
Apr 24, 2015
3,561
I suspect it may be an OEM part and nothing I have ever come across including parts catalogues such as Digikey etc.
What is the name/type of equipment it comes from.
M.
jayanthd
Jul 4, 2015
43
It looks like a car door lock/unlock switch. There will be a small rod like thing at each window of the car and you press it and the doors lock. If you pull it up the doors unlock. Is this what you are referring to. I think it is related to automobile electronics.
dolev1986
Sep 7, 2015
Hi ,
Yes , its a a car door lock/unlock switch.
this component is incharge the AUTOMATIC SWICH for the drive.
jayanthd
Jul 4, 2015
43
Yes, if the doors doesn't lock the engine won't start. Part number is needed to search for the component. Usually in our country (India) all models of car use the same type of switch and it can be bought in automobile parts shops.
Minder
Apr 24, 2015
3,561
Here a good local source is a local auto wrecker especially the self-strip parts ones.
M.
