exxos
- Jan 1, 1970
- 0
Hi all,
Trying to solder QSOP16 packages to a PCB by hand, bascially just have the
PCB cooking ontop of a infrared bar heater and simply bunging the IC ontop
when the solder melts... apart from getting the IC to align it does a good
job at soldering the IC, only problem is the heater burns the board with a
500W bar, I will connect my variac to it and try it at a lower power which
should help, though my question is, is there any infrared heaters which can
just give a narrow beam of about 5mm ? At least that way I can just heat the
IC area and not the entire PCB... Thinking also about any high wattage
lights is took down to a narrow beam would probably get hot enough to melt
solder....
Using a soldering iron is out of the question in the normal way, I could
invest in a flat tip and heat a square on the reverse side of the PCB, that
would probably work also....so.. anyone got any ideas for a narrow beam
heatsource ?
Cheers,
Chris
solder....
heatsource ?
Cheers,
Chris
