Triggering a passive infrared sensor?
tomadom
Jan 18, 2013
81
I have some security cameras that need to be placed behind glass. Unfortunately, to detect motion, they utilise a passive infrared sensor and hat won't work through glass
I want to make a simple circuit such as a small passive infrared sensor for outside the glass that triggers something behind the glass, say inside a car, that would in turn trigger the passive infrared sensor on the camera. Basically I will need something that will generate infrared heat. I have considered a 5 ohm resistor with a five volt current running through it but I'm not sure if that would trigger the passive infrared sensor. I'm told and infrared LED won't work on its own.
It will need to be low voltage and simple. Does anyone have any idea how I could do this?
14,317
Typically these passive infrared sensors (PIR) work not by detecting infrared radiation alone but in combination with motion. Using a stationary resistor to create a thermal signature alone will very likely not help. The resistor would have to move across the visual field of the camera's sensor.
You will have to tap into the camera's trigger circuit to circumvent this issue.
bertus
3,877
As said a pir sensor reacts on movements.
The movements are detected by a fragmented lens.
Read the following article for more details:
Bertus
danadak
Feb 19, 2021
1,104
Melexis Infrared T sensors a possibility, available in various angles :
These sensors not passive though. Intelligent (signal conditioning) would be more accurate description.
Regards, Dana.
tomadom
Jan 18, 2013
81
yes, thanks, that's what I'm considering. Maybe by accessing the input notes for this PIR sensor I could also create a temporary connection for a sensor that I can connect to a wire and place outside the window. I do notice that the security camera sitting opposite camera 1 seems to set camera 2 off when it starts recording. I see a bright light from camera 1's lens when viewing it from camera 2. That light seems to be setting it off but I don't know how reliable it is.
tomadom
Jan 18, 2013
81
Regards, Dana.
Thanks for that.. I'll look these up.
tomadom
Jan 18, 2013
81
I'm back at this again and I have a few more questions.
My Wi-Fi camera has a passive infrared sensor built in. Does anyone know what happens once that passive infrared sensor is triggered? Does that sensor just complete a circuit similar to the way a transistor does when a current is applied?
I am actually going to make some connectors on the outside of the camera so I can attach a microwave sensor module which I will power externally. Is it a simple as closing the circuit with a transistor triggered by a microwave sensor at the point where the passive infrared sensor is soldered to the circuit board?
If any of you were to do this how would you go about it?
Thanks again.
Delta Prime
Jul 29, 2020
2,996
Like I did last time…I got the specifications of my aunts PIR system; voltage,current requirements (power ground & signal triggering). Went shopping and found out. They were almost identical,a direct swap! pin for pin replacement..
Passive infrared sensors detect the change in infrared radiation emitted from a moving object within its field of view.
Microwave sensors detect movement as well, but use radio waves.
If you’re gonna go microwave, go Doppler radar ; you can see through walls. They have the same voltage and current requirement as a PIR system. experimentation is in order because there will be a lot of false triggering, depending on your surroundings. below is what I used.
https://github.com/jdesbonnet/RCWL-0516
tomadom
Jan 18, 2013
81
Point taken about doppler radar. I'll look into this. However, I'm at the point of determining whether there at the location of the connection of that PIR sensor to the circuit board, whether any sensor just connected to it is just 'closing a circuit' as opposed to applying a current? The reason I ask is that I'm planning on leaving the PIR sensor fixed to the circuit board and then adding the microwave or doppler sensor? Do I need a transister?
Delta Prime
Jul 29, 2020
2,996
I can’t answer your question without more information :( Make, model, schematic?
What is your application?
tomadom
Jan 18, 2013
81
I was just asking generally how this kind of thing works? You will not find a schematic on these.
tomadom
Jan 18, 2013
81
I managed to pull apart the camera with the built in PIR sensor and have taken down what is written on the front of the sensor. I can't seem to find the specs online. Does anyone know how to go about finding the specs for this PIR sensor.
On the face of the sensor it says:
NICERA
200F12
360
I've emailed NICERA but it's unlikely I'll ever hear from them
Delta Prime
Jul 29, 2020
2,996
Have you seen this? Can you take a photo of your board please?
I hate playing where’s Waldo!
Any and all information you can give me…
Thank you.
“I went to the bookstore and asked the sales woman where is the self-help section? She said if she told me. It would defeat the purpose..”
-George Carlin
tomadom
Jan 18, 2013
81
Thank you.
-George Carlin
I
I've seen that page but it doesn't help.
Pics below.
bertus
3,877
I have no problem in brave.
I have attached the file.
Could it be the RE200B in the pdf?
Bertus
  • 1472896616329.pdf
