Internet schematic OK
tedstruk
Jan 7, 2012
476
I wondered if you could look at this and tell me if itsOK or if it would be a failed build?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
It helps when discussing circuit schematics to have ALL the components labeled. For example, R1, R2, ... Q1, Q2, ... D1, D2, ... etc. like that. Your hand-drawn circuit with the 1N4148 diode, 1 kΩ resistor, and unidentified NPN transistor doesn't look right. What is this part of the circuit supposed to accomplish? Where did you find this circuit diagram, or did you scheme this up yourself? Have you built this yet? If so, what were the results?
73's de Edd
Aug 21, 2015
3,730
Sir Tedstruck . . . . .
With " the rest of the story ". . . .and using with an 80-100 watt panel . . .and don't "over expect", even with that.
It certainly seems so.
73's de Edd
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Thanks, @73's de Edd. Looks like it might have a chance of working... how do you find this stuff, and so quickly too?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Ah! I keep forgetting Google can search images...
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Beats me why @tedstruk bothered to hand-draw the schematic when he could have posted a link to it!
According to his information page, he is retired and disabled. Perhaps hand-drawn schematics is one form of therapy for him, just like picking up electronics again after age 9 and his frightening experience when
"I built a circuit from an antennea array and a 9v battery that created a static ball about 6 feet in diameter that scared experimentation out of me."
Static balls are no fun to play with, what with all the hissing and sizzle and erratic motions reported to occur with such phenomenon. Perhaps "getting back on the horse that threw him" is also a form of therapy.
tedstruk
Jan 7, 2012
476
good good now the tuff stuff....!!
there are no dinosaurs in an amp right, and if your solar panels decide to poop out when the sun goes down, you can still use the trickle energy to create signal ... so I decided to throw this one together so I don't look like an internet theif. I remember something about not enough power is worse than too much, but the panels only put out about 1.6v in a window lit room, The .16v is an arbitrary "at night with no moon" number I got out of the 1.6 with the decimal moved one point to the left...and this way I am supposed to remember the right hand rule...!!!(so far so good!lowvolt.jpg )
tedstruk
Jan 7, 2012
476
Now I remember why they said it wouldn't work. They said all the components that are made, are made to handle signal... there are no transistors, capacitors or resistors that are designed to do this kind of work. They said If I had a source, I would be ok... well aren't solar panels a source?
@tedstruk can you tell us what you're trying to do.
Your circuit 2 posts above looks like nonsense.
Are you trying to charge a lead acid battery from a solar panel?
