Sasi,Sasi said:Here is the charger, we assembled this circuit seperatly for charging 12V 250AH battery with a current of 30A max (15.1V). set the float current 1A
we used a stack of eight 2N3055 transisters with 0.1ohm 10watt emitter resistor
hi audioguru,audioguru said:Hi Kachew,
A sinewave inverter schematic was posted that was a function generator IC making a sinewave that was amplified by a linear audio amp then stepped up with a transformer. because its amplifier is linear, it wastes a lot of power as heat.
I don't know how to filter such a high power circuit. Some UPS's use a custom-made "ferro-resonant" transformer and have a sine-wave output.kachew said:can i use the inverter with the square wave output ( that is done by kasamiko and audioguru) and filter it (using low pass filter) to be sine wave inverter?
You didn't attach a circuit here. You attached a circuit without part numbers in another forum.can anyone suggest anything to be modified from my circuit attached?
I don't know about any books.grateful said:Hi,audioguru
i'm interested in constructing a pure sinewave inverter. Do u know any books that talk about how to design this kind of inverter?
the ferro-resonant transformer that u mean is it same as the ferromagnetic transformer ???/quote]
Google has many links to explanations and sales of ferroresonant transformers.
