Check the input voltage spec to be sure. The only 'specs' I see look sort of like this:
Power Supply: DC 9V: Dry battery (R6/LR6 (AA) type) x 6, AC Adaptor (PSA-series)
Current Draw: 120 mA (9 V max.)
Accessories: Owner’s Manual, Dry battery (AA type) x 6, Sound Library for RC-20XL (Sample Phrase CD)
Options: AC Adaptor (PSA-series), Foot Switch (FS-5U)
Alternatively you could add a simple 3-terminal linear regulator such as the 7809 9V, 1A regulator detailed below. Since it is rated at 1A and you are asking for 500mA you are 50 percent derated and probably safe to operate. For additional protection you could add a heat sink or mount the tab to a metal plate/case.
These are common devices and there is a chance that any local radio or hobby shop may have one in stock.
A greater concern is - how did you 'fry' the batter pack? Is there some operational issue or scenario to be concerned with or other root cause that you want to address?
LM7809ACT-ND
Price ea. $0.70
Manufacturer Fairchild Semiconductor
Manufacturer Part Number LM7809ACT
Description IC REG 1A POS VOLT 3TERM TO-220
Family PMIC - Voltage Regulators - Linear (LDO)
Series -
Regulator Topology Positive Fixed
Voltage - Output 9V
Voltage - Input Up to 35V
Voltage - Dropout (Typical) 2V @ 1A
Number of Regulators 1
Current - Output 1A
Current - Limit (Min) -
Operating Temperature 0°C ~ 125°C
Mounting Type Through Hole
Data Sheet -
http://www.fairchildsemi.com/ds/LM/LM7805.pdf
