Safe to use 12V 800mA DC converter for 9V 100mA DC appliance?
The converter that comes with our baby monitor has output of 9V 100mA
DC.
I would like to connect the baby monitor in a second location using
another
converter which is 12V 800mA DC.
I tested it and it seems to work just fine, but is it safe? Will it
burn out the appliance?
Is it a fire hazard?
Thanks in advance.
Roger
Lacy
This is just my opinion, but the monitor isn't going to draw anymore current
than it needs to operate and the adapter is going to run cooler than the 9V
unit because of less stress on it.
I cannot say it is safe or unsafe( since I don't work for UL). Just keep an
eye on it for a while and if no smoke or strange odors are noticed I would
say you would be OK.
I recently replaced a battery in a portable bearcat scanner. Ther orginal
battery was a rechargable 4.7V pack. I put in a standard 9V Battery (which
is double the voltage) and it is working actually better than before.
Besides, I really didn't want to fork over $48.00 for a new battery Pack.
The only thing I lost was recharging capability.
Mike Berger
Expect it to fail early. Those cheap converters usually put out
more than the nominal voltage and only drop when sufficiently
loaded. You're delivering a higher voltage than the circuit
was designed for and there's not a lot of margin in cheap
electronics these days.
Geo
DC.
On the label maybe - what is it really?
another
That may be what is says on the label - but try measuring it with a mete - could
easily be 18 volts.
Not without measuring its output voltage and checking the rating of the
components within the baby monitor.
Will it burn out the appliance?
It might pop some capacitors - if a 9 volt supply is specified than the
amplifier design will probably use 12v electrolytic capacitors
Possibly.
Geo
Lacy
Usually the connected component has a zener or some other form of regulation
that regulates the voltage to say your 9V. So even if the voltage at the
plug is say 18V which is probably the Max it could rise, I wouldn't think it
will fail any sooner, after all it is only seeing the 9V to the circuitry..
I have done this numerous time with my item s(because I usually lose the
adapter specific to that item) and I haven't had any problems..
It comes down though to what you feel safe doing. I would suggest buying a
universal adapter that has adjustable Current and Voltage so that you can at
least have peace of mind. Everyone here is going to have different opinions
about this and probably everyone will be correct in their statements. But
doing what I have stated may make you feel better about it.
Lacy
Now THERE'S a rash statement.
These things run the gamut.
Berger's take seems closer to the norm.
Not a rash statement, just years of experience. Your an idiot if you don't
design a circuit with regulation especially if the voltage is coming from an
external source. I have even seen battery equipment use regulation (take for
instance my scanner I recently modified from a 4.7V to a 9V Battery). It
didn't burn up, smoke at the instant power was applied, then it is
regulated. I didn't even open the case to look for regulation, I already
knew it was there if the designer was worth anything. Besides you missed the
part where I said "Usually".
He said in is original post he had already hooked it up and it seemed to
work fine no smoke, no fire, no abnormal operation. Therefore you can assume
regulation of some kind.
Lacy
I would like make an addendum to my last statememt before someone jumps in
with thier comments. The scanner I modifed was a Bearcat Scanner. The
designers of these are top-notch, that is why I had no fear to do what I
did. I trusted their design knowledge and years of design experience to have
what I suspected was a well designed unit and not just some piece of junk
someone threw together. to make a buck.
So it boils down to whether the item is made by a reputable company or not
as to the quality of the design.
Mike Berger
You must not be familiar with some of their 1970's vintage
models.
JeffM
[You're] an idiot if you don't design a circuit with regulation
especially if the voltage is coming from an external source.
Lacy
That would depend on the specification you were given.
In the competitive world of commercial electronics,
COST may me the primary concern.
You've never heard of Bean Counters
arbitrarily removing components for price reductions?
You've obviously not heard the story from several years back
about the recall on the baby monitor
that kept catching on fire when used as instructed.
http://66.102.7.104/search?q=cache:...oducts+Deluxe-Baby-Monitor-Model-602+fatality
http://66.102.7.104/search?q=cache:...r+recall+OR+recalled+fire+-Fire-Extinguishers
Lacy
You're right it is one of the newer type. Bearcat 150 Sportscat Portable. I
took a chance doing what I did knowing that I could have fried the entire
thing. But it was useless anyway without a battery. Their rechargeable are
just about as expensive as the entire radio. so I figure I had nothing to
really lose.
K
Ken Taylor
Sorry, but this is bad advice. While the adaptor probably won't give a
toss about the low load, the load (the baby monitor) will doubtless be
stressed by the high voltage and die early. The Bearcat scanner is a
different kettle of fish entirely - it likely has extra circuitry to
protect the device from incorrect power sources, which won't be present
on a base-level consumer product.
Cheers.
Ken
K
Ken Taylor
really lose.
This is the point though - those scanners are (and IMHO have been for
many years) made to quality, and for a market such as yourself who will
pay for a decent product. Baby monitors are a consumer product made to
be cheap. Expect failure.
Cheers.
Ken
Lacy
I didn't figure that into my thinking. You are right about that, especially
in this day and age of greedy CEO's. Slash a million here and there so he
can give himself a raise.
I know that if I would ever design a circuit, especially one for public
sale, it would have regulation and every safety feature I could put in it.
But that the way I think due to being in the industruial sector under tight
laws, namely MSHA (of course their not what they used to be either).
JANA
It is strongly recommended to not exceed the voltage rating of a product. In
most consumer products, they are very sensitive to over-voltage. Running the
unit on more than the rated voltage will reduce its lifespan.
As for a fire hazard, in my opinion, I would not think it is likely. All
that will most likely happen, is that the unit it is feeding the
over-voltage to, will fail sooner.
JANA
_____
DC.
another
Thanks in advance.
Roger
