Issue With My Tektronix 2430A
CrustyCowboy
Jul 5, 2024
3
I purchased a Tektronix 2430A from a flea market today. It passes all of the startup tests. When I press the Menu Off/Extended Functions button, it won't exit the testing screen.
I've watched videos on YouTube to see what I am doing wrong but from what I can see, I'm doing it right.
Any advice would be appreciated
Delta Prime
Jul 29, 2020
2,995
Have you tried the Tektronix website?
The Tektronix 2430A service manual can be downloaded Here.
Delta Prime
Jul 29, 2020
2,995
all it needs is a new NV ram battery. (just did this hours ago for same reason,)
the book is clear, it says and I simplify, if CKsum fails, ignore all other errors !!! (that is because all amp offsets are lost and all self tests will fail)
all 2430s do this and is a simple fix,
replace the battery Keeper-II (early models, like mine is)
or if no keeper bat there. (last models are)2430a , replace the Dallas Nvrams DS-nnnnn SRAM, they have a battery inside.
CrustyCowboy
Jul 5, 2024
3
Since I've had it the CKsum passes everytime, except for once. After restarting it after it failed, it's passed everytime. How can I tell which model 2430A I have? What's your thoughts?
Delta Prime
Jul 29, 2020
2,995
Apologies if you already have these two documents.
information on the self test and diagnostics is found in Appendix A.
  • User Manual.pdf
  • TEK 2430A User Reference Guide.pdf
