JFET Mic Pre Advise Please
evengravy
Jun 24, 2008
33
Hey,
I have been slowly teaching myself audio electronics over the past few years (part time). My knowledge is somewhat lacking to say the least, so please excuse this. I am trying to design a simple twin stage JFET mic preamp with components I have laying around, I have plenty of these (100 x 2sk170bl, 150 x 2sk117gr) so matching for Idss shouldn
audioguru2
Apr 6, 2004
12,022
Why use Jfets? Why not use an audio opamp instead?
Why use an expensive condenser mic that needs a 48V supply? Why not use an inexpensive but high quality electret mic instead that has the 48V built-in on its electret material? An electret mic needs to have its built-in Jfet to be powered.
Your 2SK117 Toshiba Jfets have a wide range of IDSS and transconductance (voltage gain). A resistor from the source to ground will add negative feedback to reduce the effect of the wide range of IDSS. It can be bypassed with a capacitor to keep the AC gain high.
A gain of 59dB is almost 1000 times so talking at a normal level to the mic (10mV output) will result in an output from your preamp that tries to go to 28V peak-to-peak.
You saved and posted your schematic as a fuzzy JPG file type instead of as a very clear GIF or PNG file type.
Hero999
Oct 28, 2007
2,433
I don't see anything wrong with the schematic, it's not fuzzy, audioguru should think about getting his eyes tested. ;)
JPEG is only bad if it's set to low quality or the picture has been edited loads of times. I recommend PNG or GIF schematics but I certainly wouldn't chastise anyone for using JPEG, as long as it's clear.
Wikipedia explains the JPEG quality setting. Simple painting programs such as MS Pait don't allow you to set the quality, real image editing programs such as Adobe Photoshop and Gimp do.
http://en.wikipedia.org/wiki/Jpeg#Sample_photographs
I would recommend an op-amp such as the TL072 but I know it's probably not a solution as you require a discrete design.
Does it have to be all J-FET?
Can you use bipolar transistors as well?
I'd recommend using a J-FET for the input stage and BJTs to provide the gain.
The phantom power supply needs to be DC to a transformer can't be used. An AC coupling capacitor can be used to connect the microphone if its floating at a different DC voltage to the amplifier.
evengravy
Jun 24, 2008
33
Firstly thanks for the responses guys,
Audioguru: "Why use Jfets? Why not use an audio opamp instead?" i am looking to avoid opamp designs for personal reasons, I hate the fact the signal goes through so many stages, i love the sound of jfets and their gracefull distortion/overload characteristics.
"Why use an expensive condenser mic that needs a 48V supply?" well... I work in a professional recording studio as an engineer and working with phantom powered mic's is completely unavoidable.
"A resistor from the source to ground will add negative feedback to reduce the effect of the wide range of IDSS"  The idss is 4 - 6ma for the 2sk117gr that I have so the spread is not so wide in comparison to other JFETs although still a wide enough variation I guess, I will look into this, thanks, how do i calculate the source resistor and drain resistor to bias the FET correctly?
"A gain of 59dB is almost 1000 times so talking at a normal level to the mic (10mV output) will result in an output from your preamp that tries to go to 28V peak-to-peak." ok,  so I would need to limit the gain somewhat in the first stage, I was thinking this would be an issue, how would I go about this, resistance on input? also would increasing the source voltage to 36V help in this regard?
thanks for responses, also sorry about the image, it is perfectly clear when previewed on my machine.......
Hero99 "Does it have to be all J-FET?" well I would like to keep it that way really yes, the toshiba parts are beautiful sounding to me.
"The phantom power supply needs to be DC to a transformer can't be used" not sure what you mean by this could you clarify please
"An AC coupling capacitor can be used to connect the microphone if its floating at a different DC voltage to the amplifier." I am aiming to have two independant power supplies, one at 48v for phantom powering and a seperate supply at either 24v or 36v for the preamp.
thanks again guys
Hero999
Oct 28, 2007
2,433
Why not use an audio opamp instead?  i am looking to avoid opamp designs for personal reasons, I hate the fact the signal goes through so many stages, i love the sound of jfets and their gracefull distortion/overload characteristics.
More stages of amplification = more gain = more negative feedback = lower distortion.
A correctly designed op-amp circuit will have much less distortion than any circuit lashed together from transistors. If the circuit is properly designed the you won't have to worry about distortion, graceful or otherwise because it will never clip.
Check out the LM4562 which has a THD of just 0.00009% which is much better than any discrete amplifier and far below the level you can hear.
http://www.farnell.com/datasheets/90066.pdf
It's quite expensive but you get two op-amps in one package which you can use for stereo.
http://uk.farnell.com/national-semiconductor/lm4562na-nopb/op-amp-audio-dual-hf-8-dip-powerwise/dp/1685366
audioguru2
Apr 6, 2004
12,022
The voices of most TV announcers and reporters are badly clipped.
The sounds on some CDs are badly clipped.
But a vacuum tube or Jfet clips "gracefully" and does not sound as harsh as an opamp that is clipping.
I have heard many compressors that cause horrible distortion because their attack time is too slow and allow the signal to blast though with severe distortion until its level is cut down.
Hero999
Oct 28, 2007
2,433
But a vacuum tube or Jfet clips "gracefully" and does not sound as harsh as an opamp that is clipping..
If the source is clipped, then it doesn't matter how good your amplifier is, it won't sound any better.
evengravy
Jun 24, 2008
33
The overload characteristics are exactly why I want jfet, I can design an opamp preamp quite easily and don't want to go down this road again as I already own some very low noise opamp pre's, some based on the ina217 which I built recently, these are very very good but opamp designs from a personal sonic perspective always sound somewhat clinical. Clean sound is not always what is required during a recording session.
Although in electronics design you aim to reduce distortion as much as possible, in my case the distortion characteristics of the jfet, which are similar in respect to tube designs, is exactly the attraction. Also I want to learn how to properly design Jfet circuits. The aim for me is to have a circuit which can be offer clean amplification at average gain settings but can also be overdriven slightly if that overloaded tone is warranted.
Appologies for sticking to my guns on this one, but I am looking to learn these technologies also.
Hero999
Oct 28, 2007
2,433
Disclaimer I'm no expert with discrete JFET amplfiiers.
Just a few things I've noticed about your circuit:
The gates of both transistors are biased at 0V which will bias them too far on. Ideally Vgs should be kept negative and should never exceed the 0.6V turn on voltage which will probably happen to Q2 on positive cycles.
There's no negative feedback which can't be good distortion wise.
Is R9 supposed to be the load?
The output impedance is 4.03k so it won't be able to drive a 49.9R load.
What purpose does R3 serve when it's in parallel with a 10k resistor?
What does D1 do? It looks like a clamping diode to protect the input. Why use a zener rather than a normal silicon diode? A normal silicon diode will do.
How much of the amplifier design is going to be JFET?
If clipping occurs in the power stage it'll sound horrible unless you're using valves (tubes) which generally sound inferior to solid state components when not clipping.
audioguru2
Apr 6, 2004
12,022
I think Mr Evengravy records electric guitars so he likes the even harmonics distortion caused by Jfets and vacuum tubes. He also likes overdrive but not the severe clipping distortion produced by opamps.
He is lucky that the Japanese Jfets are binned into fairly low ranges of conductance.
evengravy
Jun 24, 2008
33
"think Mr Evengravy records electric guitars so he likes the even harmonics distortion caused by Jfets and vacuum tubes. He also likes overdrive but not the severe clipping distortion produced by opamps. "
pretty much spot on, the pre will have DI input for guitar plus a transformer to allow mic input/phantom power and pad switch on secondary of transformer.
I bought so many of the toshiba parts for this very reason, shame they don't make them any more. :(
"The gates of both transistors are biased at 0V which will bias them too far on"
thanks, I thought this would be an issue, after some reading today I'm pretty confident I know the correct way to select a source resistor to bias correctly.
"Is R9 supposed to be the load? The output impedance is 4.03k so it won't be able to drive a 49.9R load."
R9 is connected to the xlr port grounding pin 3, to be honest I found this value is common on many preamp outputs so this is why it was chosen. Is this inncorrect then?
"What purpose does R3 serve when it's in parallel with a 10k resistor?"
Oh yeah, this should have been removed, I began by designing a single stage and was left over after the copy/paste of first stage if i remember correctly.
"What does D1 do? It looks like a clamping diode to protect the input. Why use a zener rather than a normal silicon diode? A normal silicon diode will do."
Since I intend to use the unit as a guitar DI as well as a Mic preamp this zener diode was to protect the input Jfet from voltages from accidental hot plugging, so a silicone diode will work in this case, I think the value should be closer to 1v (if these are available that is)
"How much of the amplifier design is going to be JFET?"
well i've been doing some more analysis today with average mic output data obtained from spec sheets:
Max dBu (approx 140dB spl) = +10dBu (2.45 Vrms, 3.46Vpk )
High dBu (approx 130dB spl) = 0dBu (0.77 Vrms, 1.08Vpk)
Loud dBu (approx 120dB spl) = -10dBu (0.245 Vrms, 0.35 Vpk)
Average dBu (approx 97dB spl) = -36dBu (0.016 Vrms, 0.023Vpk)
with these figures the 2sk117gr can handle one stage of amplification achieving approx 34dB of gain (if my analysis is correct) so..... I will have to rethink this. I was thinking of following the first jfet stage with a bjt pair, this will give me a better impedance for the output. Although the single stage will be out of phase.
Any other suggestions are very welcome.
thanks guys I appreciate your comments/suggestions
Hero999
Oct 28, 2007
2,433
What does the xlr grounding pin do?
If 49.9R is recommended then use it.
What load is the pre-amplifier driving?
It needs to have a significantly higher impedance than 4.02k, as a general rule of thumb, it should be at least ten times higher otherwise the gain will be reduced significantly.
The input only needs to be protected against negative voltage spikes. If a positive spike occurs the JFET's gate will just conduct diverting it to 0V, you'll hear a pop but it won't be damaged. An ordinary silicon diode connected between the input and 0V will clamp the voltage at -0.6V. It's also a good idea to AC couple the input so the bias isn't altered by changing the input impedance.
Just another general comment: why are you using precision E96 resistor values for non-critical resistors? Rounding to the nearest E24 is normally good enough, i.e you'll probably find it cheaper and easier to buy a 3.9k resistor than a 4.02k resistor, same with 49.9R, I'd use 51R.
evengravy
Jun 24, 2008
33
"What does the xlr grounding pin do?"
Not sure to be brutally honest, I'll have to look into this, although it is on almost every preamp schematic that I have seen so far.
"What load is the pre-amplifier driving?"
Hmmm........well it will be driving a professional line level sound card, impedance is approx 20kΩ balanced and 10k unbalanced.
"An ordinary silicon diode connected between the input and 0V will clamp the voltage at -0.6V"
thanks for this, will the orientation be the other way round to the zener currently in the circuit?
"It needs to have a significantly higher impedance than 4.02k"
I think i have achieved 47k with the adjustments made in the image attached, one amplification stage shown for clarity. The current draw may be quite high however. comments?
"E24 is normally good enough"
understood, would there be any difference in terms of noise produced with metal film resistors vs standard E24 ones?
Note: I have the actual schematic on my own laptop at home and don't have access to it right now so please excuse the image which i have drawn.
Hero999
Oct 28, 2007
2,433
Why would you need to swap it round?
I don't think you understood me: you only need to clamp the negative pulses, the JFET's gate behaves like a forward biased diode when the gate voltage is higher than the source, which will clamp any high voltage positive spikes.
The output impedance needs to be as low as possible, for example if you need to drive a 10k, the output impedance should be 1k or less. The circuit you've attached, includes an emitter follower stage to buffer the JFET amplifier, allowing it to drive a very low impedance.
To answer your question, metal film resistors are far superior to carbon film in terms of noise, stability and tolerance.
I'm not sure if you understood when I talked about E96 and E24 values.
Resistors are normally only made in standard logarithmic value ranges. This saves the manufacturer money, as they only have to make resistors in a thousand or so values, instead of millions.
http://en.wikipedia.org/wiki/Preferred_values#E_series:_Capacitors_and_resistors
This means there's no point in specifying an 8k5 or 60R resistor, in most cases an 8k2 and 62R should suffice, if it's critical, then use other values in series or parallel i.e. 7k5 and 1k in series and two 30R in series for 8k5 and 60R respectively.
It also means it's cheaper to buy E24 values, rather than E96 values. You can normally buy 1% metal film resistors in both E24 and E96 values.
When designing a circuit you should always aim to use the lowest E-series values possible i.e don't use 51R when it could easily be 47R.
audioguru2
Apr 6, 2004
12,022
You have sketched a class-A heater. Usually the bottom transistor is connected as a constant current sink but yours is turned on hard all the time. Use a resistor instead of the bottom darlington.
Metal film resistors produce a little less noise than carbon film resistors and also are made in 5% tolerance.
Hero999
Oct 28, 2007
2,433
I thought it was supposed to be a pre-amplifier?
The bottom transistor is set up as a constant current sink, albeit not a very good one. The trouble is the current will be 63mA which is far too high for a pre-amplfier and will melt a small signal transistor.
It might not be this bad, he did say the circuit is incomplete so we'll have to wait for the final version.
evengravy
Jun 24, 2008
33
"I'm not sure if you understood when I talked about E96 and E24 values"
oh i understood ok, just wondering whether metal film E24 values are superior to carbon E24 values in terms of noise.
"You have sketched a class-A heater.."
haha, might be usefull its freezing here in ireland
ok, heres the full first stage with part numbers, Q4 is a Darlington which was chosen merely due to its voltage rating and I was under the impression that using a darlington would minimise loading on the jfet (higher input impedance)
the bc635 is a generic npn, again chosen due to its voltage rating suiting my supply voltage (technical I know).
really just trying to achieve a source follower for impedance. can you recommend part values and arrangement at all?
thanks again guys, really helpfull.
Hero999
Oct 28, 2007
2,433
Using a Darlington is good because the gain is higher, (normally 10,000 without looking at the datasheet) meaning the input impedance will be higher.
Why have you insisted on a non-standard value  (8k5 isn't even an E192 value) for R1, is it merely because you have it in stock?
As mentioned beford, the current though Q3 and Q4 is too high.
4.332mA through Q1 seems too high, if it's correct, it means the drain will be at 1.56V and the output will be biased close to 0V so the constant current sink won't work. I think it's more likely to be about 1.6mA so the drain voltage will be about 22V.
Increase the value of R2 to reduce the current through Q3; hint: the base impedance is equal to the Hfe multiplied by R5.
Even better, add a couple of diodes between Q3's base and 0V to make the current virtually independent of the power supply voltage and if you don't change the value of R5, the current will be 6mA which is perfect.
