LCD Display of Same Specification doesn't work
Electrical_Shocker
Oct 24, 2017
20
I have replaced a Newhaven LCD Display Part Number -
NHD-0216XZ-FSW-GBW with the Hantronix display HDM16216L-5-Z1BS. The specifications look the same. Any idea why they wont work ?
  • 04627259.pdf
  • NHD-0216XZ-FSW-GBW.pdf
What do you have on pin 3, which is usually a pot to adjust for contrast? If you have put a fixed voltage, the new display may need a different voltage.
14,308
Likely. The blocks can appear when contrast is too high so that even a light pixel becomes dark.
Yes. If you answer my question, I might be able to help.
So, let me re-phrase it.
What is pin 3 connected to?
Electrical_Shocker
Oct 24, 2017
20
Here is the schematic . . Please help me how should I reduce the voltage?
  • Schematic_Prints.pdf
Electrical_Shocker
Oct 24, 2017
20
So I tried changing Voltage across pin 3. It only changes contrast of the blocks that are displayed. Doesn't show any characters still.
OK, that rules out the contrast issue.
Normally, that means initialization has not succeeded. If you are not using the busy bit, increasing delays a bit might help.
Not without reverse engineering.
I suggest you try to find the exact replacement if you do not have the code.
Electrical_Shocker
Oct 24, 2017
20
I thought the Newhaven is the exact replacement. Any suggestion which one would be the exact replacement to the Hantronix one? . Thank You for response.
Electrical_Shocker
Oct 24, 2017
20
Replaced LCD part number
Newhaven NHD-0216XZ-FSW-GBW with the Hantronix display HDM16216L-5-Z1BS. The specification are the same but this gives me blocks as output on LCD screen.
I also tried the Lumex LCM-S01602DSF/A display but again the result is the same.
I am using microchip PIC16F627A microntroller for this. As this is a old program I only have assembly language (.asm) and .hex file for this. .hex was the original file. I somehow converted it to .asm using mplab.
Any suggestions guys?
  • 04627259.pdf
