Led display Digital Voltmeter question
PeterG
Jul 17, 2004
5
Hi all,
I've just finished my DVM (with 7805/7905 power supply) and for a minute, it worked well (zero reading with no input voltage, correct reading with input voltage). Good! :)
Then I've fiddled around with the wires and, for some reason beyond me, the DVM ceased to work. Now it keeps showing a crippled (but bright) 3 on the first digit (a 3 without the upper and lower bar). When I switch the DVM off and on again, the 2nd, 3rd and 4th digit show a (seemingly random) value for a split second and then the funny sign on the 1st digit comes back. Bad! :'(
I've re-soldered anything. Didn't help (as expected). Anyone has a hint on what to do? It'd be appreciated.
Peter
MP1
Dec 7, 2003
3,397
Did you read the fixes to this circuit that were posted in the "General" area? If this is all good, I would check the voltages to the chip and then check wires to the display. Since you had a working circuit and it stopped working when you moved the wires, I would recommend a real close look at the wires. Look for breaks, frayed wire, anything there.
Hope it helps.
MP
PeterG
Jul 17, 2004
5
Dang. I've written quite a lengthy reply, but when I clicked on send, the forum said I wasn't logged in and my posting was gone. Never click on send before pressing Ctrl+A, Ctrl+C. I should've learned that by now. :(
I'll repeat the most important part only:
Thanks for your reply, MP.
Is there a difference between the corrected schematic (posted my Mixos) and the PCB layout on the project page? I haven't checked that yet. I've relied on the assumption that when there's an updated schematic posted, a faulty layout would not remain on the project page. Should I have designed my own PCB layout, referring to the updated schematic? (Actually, I have designed my own layout, but I've referred to the layout on the project page.)
MP1
Dec 7, 2003
3,397
mixos is correcting these as he gets the information from those who have actually built the device and given feedback. I assume that mixos has already made this correction. He spends a lot of time keeping the site up and running also. Send a private message to admin and he will be able to give you a direct reply. You can also send a private message to billy who has built it. I have not seen billy post lately.
I do not know if mixos has fixed the drawing and board in the projects section or not. I am assuming that it was taken care of when billy and maestro were building the circuit and found the fixes and made a working version.
I do have a board layout and schematic in Eagle which I posted to the forum some time ago. A search will bring it up.
MP
Gonzakpo
Jun 6, 2004
7
Hi....
I pieced the voltmeter on a protoboard (bradboard) and it doesn't works well
The measure it's very unstable.....I think that maybe it's my fault but it's very improbable because i used the fixed schematic and i compared it with the datasheet and it was ok!!
Also it's doesn´t mmeasure well.........I tried to measure a 0-18V power suply.....and it wasn't measuring well!!!
I would like that someone help me!!!!!!!!!
Excuse my english!!.....I'm from Argentina (and i would like to write in spanish but i can't in this forum because nobody will understand me!!!)
Bueno Chau!!!.....Espero q alguien pueda ayudarme.!!!!
Emiliano86
Aug 19, 2004
12
hello, my name is Emiliano, and I have a problem with this circuit:
"I've built the project -0 to 30 PSU-, and I decided to built this Voltmeter to conect it directly to the output from the PSU, but when i do that the Voltmeter turns off, I test the Voltmeter with another power and i worked.....I think that it could be because in te PSU project I have 70,02 V AC at max power (30,1 V DC)"...I don't know!!!......please if you can help me......
thankssss.........
Emiliano86
Aug 19, 2004
12
gonza.....why don't you try with the pcb pulicated on this web.....i used it and it worked!!!.......i'm doing some adjustments!.....but it works!!.....
(i'm from argentina too!!)
MP1
Dec 7, 2003
3,397
Emiliano, the final fixes for the project were posted in the Feedback section of this site. You can find the information here:
http://www.electronics-lab.com/forum/index.php?board=4;action=display;threadid=353
NOTE: WAS MOVED. IS NOW HERE:
http://www.electronics-lab.com/forum/index.php?board=13;action=display;threadid=1516
MP
Gonzakpo
Jun 6, 2004
7
OK Emiliano.....voy a seguir tu consejo (I WILL TAKE YOUR ADVISE).......
Now I'm doing the PCB but i have a questio:
WHICH R1 SHOULD I PUT?? 180K or 100K???
The kit says that R1 is 100K but in the datasheet 180K
What should i do?
Thanks!!......(AGUANTE EL PIO IX)
audioguru2
Apr 6, 2004
12,022
Hi Gonz,
The "fixes" discussion that was posted a couple of days ago says to use 100K for R1.
Gonzakpo
Jun 6, 2004
7
OK thanks
Now I've just finished making the pcb but i have to make the holes so i'll wait to monday to do it in the sochool (I go to an industrial school called PIO IX).
Meanwhile I wonder If there's something else anyone should tell me about the pcb or the components....
Any more fixes apart from the R1?.....(I don't want a link, i want you to tell me if there is anymore fixes I don't know..........just to be sure)
Well that's all.......bye
MP1
Dec 7, 2003
3,397
There is no reason to exhaust the subject or make repeat posts. I posted a link a few messages back. I recommend you look at the link. For more information on it, learn to use the search feature. It is posted at the bottom of this message.
MP
BlacK1
Aug 24, 2004
can i use any 7-segments anode lcd dislpay ? or i have to use that man6960 'cause i cant find it in my country
MP1
Dec 7, 2003
3,397
I have no idea. It depends on what you have available or what you want to use inplace of it. Compare the data sheet of the one you will use with the MAN6960 data sheet.
Data sheet is attached here.
MP
MAN6960.pdf
  • MAN6960.pdf
BlacK1
Aug 24, 2004
or maybe there is eletronic shop that sell those in worldwide ? and can i use only 2 displays for 0-20 voltage ?
arni2824
Aug 31, 2004
i am interested to know if i can use commercially available common anode seven segment display instead of man 6960.
MP1
Dec 7, 2003
3,397
You can use any LED you want. Check the data sheet above that I have attached to my post. The A1, A2, etc pins are the segments. Just follow the pin out of the two different types. Be careful, though. Some LEDs are common cathode and some are common anode. If you choose the opposite type, you will need to add a little more hardware to make it right.
MP
charliecuattro
Sep 6, 2004
15
hi,
i have an power mosfet inverter dc to ac , works with 24volts
instead of using a battery for the voltmeter, can i use same battery under measuring as source for the circuit it self ??
sorry but i'm jut a hobbyst
thanks
MP1
Dec 7, 2003
3,397
This has been discussed in the original project posting area. You cannot use the voltage you are measuring as the voltage to source this circuit. It must have a stable unchanged voltage as a source.
MP
