From what voltage source? Batteries? Power supply unit? Wall wart?
To get the right mA to your LEDs, use this formula:
R = (Vs - Vl) / I
where R = resistance
Vs = power supply voltage
Vl = sum of LED voltages (check, but probably 2v ea)
I = LED mA = 30mA
you could hook them all up from a 12V DC source - having 5 LEDs per 'leg' and have 10 'legs' in parallel.... with some quick calculations that's
R = (12 - (5x2)) / 0.030
= 67
so you have 5 LEDs hooked up in series with a 67 ohm resistor....... then hook up 10 in parallel with power supply.
the circuit draws 30mA x 10 = 300mA
so you just need a 12V DC power supply capable of delivering 300mA (easy to buy, find or make!)
