First let me apologize to Alun and others for any confusion my post of the
formula to calculate the freqency. As it turns out the formula is incorrect.
When I did the calculation I got a negative number. I knew that could not be
right so I ignored the - sign.
I did some checking and find that the calculation is a little more complex, but
the attachment shows a general formula that is extremly close when the Vcc is
9V.
Audioguru is correct about the reverse-biased transistor. In the case of the 2N3904 my current data books did not list the maximum negative bias for the subject transistor, so I actually measured the avalanche and found it to be
very close to 7.5 volts. Actually measuring the - bias of the circuit my scope
showed 5.2 volts.
