Led / Lcd tv running on 12v battery
G S ng
Hey All,
Our family has just bought a camper van. Will be used mainly at unpowered
locations, but not too far from relative civilisation.
Been looking at fitting it out with a few comfort accessories for the wife &
kids, including a Television.....
The camping & 12volt specialist mobs have "purpose made" 12v led / lcd tv's
which retail upwards of $300.00 for 19 inch screen.
I recently noticed that most of the cheap house brand tv's like Kogan, Dick
Smith etc 19-24 inch tv's have 12v input from switch mode power supplies...
and retail for around $130...
Would the power circuits in these tv's be happy running off a 12v battery?
Would they be subject to interference from 12v pumps etc... running off the
same battery?
Was also wondering on the quality of the tuners in these cheapies compared
to the "purpose made" ones, which are also what I would call "cheaper"
brands like "Teac" "Sphere" "Majestic" "Fusion"
And finally, there is a few different types / stiles of antenna for "RV"
use... ranging from $80 up to $300.... Any advice on what the real
difference is on these?
I understand the chassis and mounting on the RV & marine specific types
could be a bit more rugged to withstand bumping around, corrosion etc... but
for something that realistically only be used a couple of times a year,
would a cheapie do the job?
Any advice appreciated.
Cheers,
Gary.
Phil Allison
& kids, including a Television.....
tv's which retail upwards of $300.00 for 19 inch screen.
Dick Smith etc 19-24 inch tv's have 12v input from switch mode power
supplies... and retail for around $130...
** What do Kogan say?
http://www.kogan.com/au/buy/19-led-tv-hd/#product_specs
the same battery?
** Maybe, maybe not.
Depends of the pumps and the battery.
** Probably good as any other.
** The more expensive one have a bit more signal gain and directionality.
So you need to point them more carefully.
You are on the WRONG forum - pal.
Try a caravaner's forum.
..... Phil
bristan
Hey All,
unpowered locations, but not too far from relative civilisation.
wife & kids, including a Television.....
the same battery?
compared to the "purpose made" ones, which are also what I would call
"cheaper" brands like "Teac" "Sphere" "Majestic" "Fusion"
but for something that realistically only be used a couple of times a
year, would a cheapie do the job?
Cheers,
Gary.
I have an older dick smith analogue lcd flat screen and stb in my caravan.
Runs off a 12v supply I don't have any problems. Jaycar have an antenna
suitable for vans /caravans. Its a good idea to fit a masthead amplifier
for those times when you are in weak signal areas.
Glenn
Hey All,
Smith etc 19-24 inch tv's have 12v input from switch mode power supplies....
same battery?
Cheers,
Gary.
Hi Gary
Can't help you with the antenna question but we have on off-grid shack downthe south coast of NSW. I run a Kogan LED TV (with built in DVD) bought earlier this year direct from battery. It is a fringe reception area and we do have a high gain antenna on the roof but get great reception, so tuner appears to be fine.
The LED TV model we have draws 3 amps so there's no special need to worry about cable thickness etc. We sometimes get some noise when switching lightson and off - however, only at time of switching. The lights are 240V CFL and draw power from an inverter connected to the same battery. You could getnoise from pumps but you could probably add a smoothing capacity to the supply point for the TV to help reduce this.
Cheers
Glenn
G S ng
"Glenn" wrote in message
Hi Gary
appears to be fine.
Cheers
Glenn
Hey All,
Thanks for the informative replies. I have read through a few of the
caravaning forums, but thought I would put up a post here as I was looking
for a more technical response. Which I did get which is great and I am most
thankful.
Looks like the Kogan Tv will be the unit of choice... I dropped in to the
local mob that does the 12v things and found there "Van specific" tv's draw
about 6amp which is about double the specified rating of the Kogan, and more
than double the price!. Teamed up with one of the cheaper Antenna (Jaycar) I
think should be fine. Not sure about masthead amplifier in this situation. I
thought these only are useful for amplifying signal for longer cable runs /
additional distribution points etc, but any advice on this would be
appreciated.
As far as noise etc. I am sure the family would cope with interference while
pumps running or lights are switching....
Thanks for the links the the "camping" forums News 13... They are a couple I
have not tried yet. Had a quick look on them last night and see there is
lots of useful information. Thanks also for the heads up on the Merit Plugs.
Those cigarette jacks have been pesky to me in the past...
Cheers,
Gary.
