question lcd led ips
bbvvaran
Mar 17, 2025
6
display IPS LED LCD is not energized frequently and is stored for many years without use, the liquid crystals will go to sleep and will not respond correctly. Will it generate problems with the pixels, leds, backlight and permanent image retention because not use long periods? i have little handheld consoles with display lcd led ips
14,293
It depends on the storage conditions. You'll have to give it a try.
ahsrabrifat
Jan 18, 2025
76
Liquid crystals can settle over time, leading to slow response times or "sticking," where they may not properly change state when powered on after years of inactivity. Turn on the device occasionally (every few months) to keep the liquid crystals active.
bbvvaran
Mar 17, 2025
6
Many years not use LCD LED ips damage in Crystal liquid IS permanent?
14,293
Your question can't be answered with a definitive yes or no.
I repeat: It depends on the storage conditions. You'll have to give it a try.
bbvvaran
Mar 17, 2025
6
What do IPS LED LCD manufacturers or engineer say about long term storage of the display? I don't have any contact from them
bbvvaran
Mar 17, 2025
6
I not found datasheet display LCD LED IPS of My consoles handheld R36S and powkiddy Q80
bbvvaran
Mar 17, 2025
6
I have portable consoles R36S and Powkiddy Q80 they have LCD LED IPS panel display and I store them in the dark inside boxes unfortunately even using a dehumidifier I can't control humidity 57-68% and temperature 34-36C if I store without power and without use for years the LCD LED IPS display will lose backlight efficiency, loss of power and efficiency of the LEDs, the liquid crystal will generate dead pixels and LCD slowness problems
