Lostgallifreyan said:
It's pretty good
Not really. In fact, it's a disaster. The only regulation
in evidence is the transformer; the only supply in
evidence is the transformer, diodes and capacitor bank.
Look at worst case: Vf 3.3, line voltage 130. Vary the
line voltage up to 130, and his 48v transformer will put
out 52v. Allowing a volt drop for each diode at ~2 amp,
that's 50 * 1.414 or 70.7 volts. At Vf 3.3, 17 LEDs drop
(17*3.3) 56.1 volts. That means 13.9 volts across his 20
ohm resistor, for 695 mA.
Disaster - almost 10 watts for the 1/2 watt resistor and
more than 27 times the target current through the LEDs.
And with 56 strings (960/17)= 56 + the total current would
be (56*.695) ~ 38 amps!
Assume it is not a 48 volt transformer. (Well right away
we're in trouble with "assume".) Lets say its a 44 volt
transformer. At 130 volts, it will put out 47.7V which
after the 1 volt diode drop (2 diodes) becomes ~64.6
(45.7 * 1.414) = ~ 64.6 volts. With Vf = 3.3 the 17 LEDs
still drop 56.1 volts, leaving 8.5 v across the 20 ohm
resistor for 425 mA current. Goodbye to one or more
of powersupply, LED, resistor. The magic smoke will get
out.
If you go with with a higher value resistor to get
..025 mA, that's 8.5/.025 = 340 ohms (best case transformer,
worst case Vf and line voltage). What happens when the
voltage is 120, and the Vf is 3.5 if you use a 340 ohm
resistor? .5/340 = ~1.5 mA and the LEDs are too dim.
He *must* regulate. *If* he posts that the 60V supply
is really a regulated 60 volts, not just a transformer,
bridge and capacitor bank, then a resistor current
limiter would be appropriate. In that case the regulator
is already there, in the supply. He has *got* to have a
regulator in there, somewhere. It's an awful lot of
work to put 960 LEDs in there - it certainly warrants
spending $13.00 on regulation.
You got the idea of getting the LED's to use all available
voltage overhead, reducing the need to get rid of waste heat.
Bad idea. He has *got* to regulate. That means a linear,
which will waste power as heat, or a switcher, which is
not under discussion here. If he is the same person who
has been e-mailing me since 6/13 under a couple of different
id's, then he has a switcher solution that is cheap ($10.00
for the switcher) and solid, but requires work: 3 LEDs per
string. He also has been given a solution in e-mail that
works without a transformer and is easier (40 LEDs per
string) - but is dangerous due to high (up to ~182) voltage.
The waste heat from the regulator is of no concern, other
than cost. It requires about 13 dollars for the LM350K
and heatsink. It is not required to be near the LEDs,
so it won't cook them.
If your PSU is
very well behaved, you don't need the regulator.
Yes, he does. It can be very well behaved, but if
there is no regulator in the supply, line voltage
variation can kill the LEDs, as shown. Varying
the worst case the other way (line voltage = 105,
Vf = 3.7) will just make them dimmer than nominal.
Just bear in mind that your
resistor is only dropping half a volt! While that's efficient, it's a lot
closer than my posts advised, so your supply is going to have to be VERY well
behaved. I think you'll find that the line voltage will vary more. 0.5V in so
is 1 V in 120V, or 2V in 240. You can be damn sure that the average mains
supply is going to drift more than this.
Exactly.
I still advise using s valve (vacuum tube) transformer for around 300V to get
strings as long as 40 LED's, and replacing each resistor with an LM317 current
regulator. You only need 6 of those then, and the performance will be far
better and far easier to control.
That's a non-starter. The differential across the LM317
would be huge. 40 leds at 3.7 = 148 volts, which means
188 volts is the upper limit if the LM317 can handle
40 volts difference. (AIRC, the max difference is 37,
but that's not worth looking up when we're talking
hundreds of volts difference)
I'd been thinking about the heat from the panel itself, btw.. I don't know what
the efficiency is for those LED's. maybe 15% or so? So not all power in will be
heat out, so at least one previous poster gave wrong figures for heat. I guess
it could be 70 watts lost, from a likely panel size of 9x30 cm. The odds are
that you won't need a fan, if you can get decent convection around the LED's.
Yes/no. A total of ~79 watts will be produced. Some of
it will be heat due to inefficiency, the rest (most, I
would think) will convert to heat both in the LED and
external (far away) to it. Light energy becomes heat
energy as it is absorbed in a surface; even a transparent
surface absorbs some and converts it to heat. So he'll
have 15% or whatever due to inefficiency, plus an
additional amount due to absorbtion. The point is not
how much heat exactly - I don't know - but how do you
get rid of whatever heat is there. If there is extremeley
limited convection, I don't know how to do it.
If it's the same person, I told him in e-mail that I was
not qualified to tell him how to deal with the heat in
the LEDs. But I doubt that he'll be able to cram 960
leds into as small an area as possible without a significant
heat problem. In the e-mail he spoke of replacing a projector
bulb with these LEDs. If he can spread his LEDs out so that
decent convection between the LEDs possible, that worry
becomes *much* smaller than what I envisioned.
Ed
