James Thompson
- Jan 1, 1970
- 0
Clip..
Whoa guys! I have not been discussing this with anyone via email, wrong
one.
And I thank everyone that is helping.
The supply in question is a basic transformer / bridge / cap, and develops
70 volt under no load. With 1 amp load it is running 59.7 volt measured for
short time across the load resistor. I am choosing to voltage regulate this
beast via a series pass transistor boosted lm317hvt regulator at the very
least. I have decided on strings of 15 led's per string with each string
having a compensating resistor. Also since I already have a board etched for
that amount.
The led's in question are 27,000 mcp with forward drop of 3.2 to 3.8 volt
and a max of 30 ma.
I now will regulate the supply voltage to 60 volt, which should hold stable
regardless of the mains +- 10 volt which may vary the dc voltage +- 5 volt.
From the 55 volt, each string of 15 will drop 52.5 volt leaving 2.5 volt to
the series resistor. 2.5 volts divided by .025 ma will make the resistor
100 ohms, and 2.5 X .025 = .0625 in watts so a 1/4 watt resistor is plenty
for this.
Now there are 64 available strings that can be filled with led's, and if all
were used it would be 64 Times .025 ma = 1.6 amp total board current demand.
That is if the supply does not sag on 1.6 amp. Like I said earlier post, it
came from an audio power amp / receiver and is a fairly big size of core
with 16 ga secondary wire.
For the present, not all strings will be used - only 56 will be filled
making the board draw at 1.4 amp.
Ok, does this look right to you guys?
If you're going to tear up a post and say four paragraphs to the extent of
saying that mains power isn't well behaved, you'd do better to quote the
context. I said that in ONE paragraph.
one.
that amount.
and a max of 30 ma.
for this.
