audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
Yeah, the cheap little 1N400x rectifier diode is too small for much current. :'(
Was it lower then 1 Volt on the output? Did you connect the right terminals? Did you use some protection diodes? Wich package did you use(TO3,TO220 etc)?As I adjusted the pot it would jump directly from around 10V down to 1V or lower
Probably not, the voltage should not go down below 1 volt then, maybee it is now.The potentiometer is faulty it probably has a break in the track
I measured the input voltage to the regulator calculated its power dissipation to be 36W.audioguru said:Alun, the chip in your LM217 must have been way over its rated max temperature. It was trying to dissipate 55W!
I don't know the LM217 has a maximum temperature of 150oC, that's 25o higher than the LM317 so it probably helps and my heat sink was experimental. I soldered its tab directly to a piece of 50mm bus bar then mounted this to the case with a piece of in between for insulation. I am aware that the device might not have survived this abuse but as I have so many of them it was worth the risk and I certainly wouldn't recommend this method of manufacture for expensive devices. This abuse may have paid off because the solder junction probebly had a very low thermal resistance because tab remained below boiling point.I am surprised that it didn't go into thermal shut-down.
Looking at the datasheet the minimum current limit is 1.5A, 2.2A typically which is 31.8% higher so statistically it could be as high 2.9A. I suppose I must've been lucky with this and as the device didn't overheat it had no reason to shut down the voltage limit is also a minimum specification which is also not very well controlled I reckon most devices exceed both these ratings.Since it had more than 15V across it then I am also surprised that it didn't cut-back its current to about only 1A.
Hi Alun,Alun said:Using a 18V 22/3A torroidal transformer the output ranged form 1.2V to 16.4V and I could draw 2.5A 1.2V
I measured 15.something, your math must be wrong because it doesn't account for the internal resistance of the primary and secondary nor the ouput ripple or the ESR of the 10,000uf filter capacitor. Sure 23.4V might be the peak off load voltage but this'll soon drop down to <18V under the high peak current and the troffs in the ripple could be <12V giving an RMS of 15V or so, I could measure this on my oscillosope if you like.audioguru said:Hi Alun,
My math shows a 25.4V peak from your transformer. The rectifiers drop it to about 23.4V.
Here is says 3oC/W.The TO-220 plastic case has a 4 degrees C/W rating.
That's 4oC/W now so 36 * 4 = 144oC which is still pushing things a bit but this makes far more sense especially when you consider the practicle results.Mounting the regulator to a very big heatsink creates a total of 5 degrees C/W.
