audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
Hi Alun,
Your 18V transformer is rated to produce 18VAC at its rated current. It isn't a little 200mA wall-wart whose voltage doubles without a load, so its internal resistance is extremely low. So low that its voltage doesn't drop much when the rectifiers conduct their massive current.
The main filter cap should have a high enough capacity to reduce ripple voltage to about 1Vp-p at full load, or the regulator is going to have ripple in its regulated output.
I used a typical thermal resistance for the LM317 because I couldn't find spec's for an LM217 nor find a max thermal resistance rating. The LM317A has a guaranteed thermal resistance of 5 degrees C/W max. The extremely high calculated temp of your regulator's chip could be even higher.
I don't think your 45W transformer will catch fire with a load of up to 55W if the output of the LM217 is shorted. The LM217 is supposed to limit the current at about 2.2A with less than 10V across it, or about 1A with 20V across it. ;D
Hi Spagbol,
Many years ago I saw audio amps using a big light bulb for current-limiting. It worked. ;D
Hi Spagbol,
