LM338 Power Suply Current Regulator
Fight
May 26, 2010
47
In lm338 data sheet asking
Features:
Guaranteed 7A peak output current
Guaranteed 5A output current
But problem is that in Electrical Characteristics:
Vin-Vout = 30V Than max current 1A
what is meaning that
lets Vin = 38V  and Vout = 8V
38-8 = 30
and Vin-Vout = 10V or less than 5A can handle
mean
38-28 = 10
mean 8 to 28V 1A handle
and 28 to above 5A handle
Attatch Diagram
2.    in Application Hints diagram all diagram is designed that can handle 5A
Attatch Diagram
hotwaterwizard2
Jan 8, 2004
2,022
Exactly what are you wanting to do here?
You Must Heatsink the components for 5 amps each if not they will only handle 1 amp each.
There is another way to make a high current power supply.
hotwaterwizard2
Jan 8, 2004
2,022
http://www.national.com/ds/LM/LM138.pdf
http://www.national.com/mpf/LM/LM338.html#Overview
Hero999
Oct 28, 2007
2,433
That circuit will have very poor regulation because the base-emitter saturation voltage of the 2N3055 will vary depending on the current drawn and the 0.47R resistors will have a significant voltage accross them.
Suppose the current draw is 0A and you set the voltage to 12V.
Then you increase the current to 5A.
@0A the VBE of the transistors will be near 0.6V.
Each transistor will have 5/6 = 833mA through it, the same for the emitter resistor.
The voltage will drop by the 0.47R resistor will be 5/6 View attachment 41026
Hero999
Oct 28, 2007
2,433
They help to ensure the current is shared equally between the transistors. The value isn't critical, I chose 0.1R because I originally designed it for high currents, for 5A you can use 1R which will be easier to get hold of.
Fight
May 26, 2010
47
if i change the value of 1R instead of 0.1R than what change in circuit current
the resistor wattage
the voltage across R = ?
the current across R = ?
Hero999
Oct 28, 2007
2,433
Changing the value will not change the current, the circuit does not provide current regulation, it's just that if the voltage drop across the resistors is very low, the current sharing won't be very good.
Fight
May 26, 2010
47
please explain it using examples
if 10R resistor use than
Fight
May 26, 2010
47
what is the efficiency of these circuit
if this method using with lm317 and lm338 than thses ic better current and voltage or not
Hero999
Oct 28, 2007
2,433
There's no hard and fast rule, I just use current balancing resistors which have a voltage drop of a couple of hundred mV or so at full current. The voltage drop can be calaculated using Ohm's law.
It's as efficient as an linear regulator.
Fight
May 26, 2010
47
ok
Quote
my mean that if using transistor current increasing method for lm317 or lm338 regulator ic than this method ok or not because volatge vary from 1.2 to 30 v
7805 or 7812 is fixed regulator
Hero999
Oct 28, 2007
2,433
The variable voltage requirement doesn't make any difference, why would it?
Fight
May 26, 2010
47
Attatch diagram
first circuit is use for current limiting
transiter is use for current increasing transistor current provide 5A at all voltage range 1.2-30V
this circuit is good
better
best
or not
Hero999
Oct 28, 2007
2,433
It's not a very good idea because the extra regulator will increase the drop out voltage by 4.2V.
