K
[email protected]
- Jan 1, 1970
- 0
The power supply still didn't work. It was then I realized (again) that
The 700,000uF worth of capacitance is connected to the output of the
regulator not because I'm try to filter the output, but because I am
trying to charge the bank of capacitors for a completely different
purpose.
I am now finding that. With this discussion especially, I know I need
to lower the voltage into the regulator. Is there an easy way to do
this without having to buy a new transformer? They are somewhat
difficult to locate for a reasonable price in my area, at least at
surplus prices which is about the only option at this point.
Would half-wave rectification be an option? I know I would probably
need even larger filter caps, but if it lowers the voltage to a
reasonable amount (but not too low...) I would save myself the trouble
of trying to find a different transformer.
Kevin
example circuitry schematics found in data books are often just used as
illustrations, never left the desk, are not tested and may not work.
I ended up designing my own power supply. It worked. I think the whole
control room is still in operation 2 decades later because once in a while
they broadcast scenes from the room and you can see the LEDS working..
Have you considered the fact that all those hundreds of microfarads in
filtering are supposed to connect to the rectifier output, not the regulator
output?
purpose.
That the voltage on your secondary will be too high? (1.414*26)?
Regards,
Kevin
