N
Nemo
- Jan 1, 1970
- 0
I've got a circuit where the signal goes through one of two low pass
VCVS filters, and the output of one of them is selected by an analog
switch (DG419).
One filter uses 1nF 2% PPS capacitors - there are various constraints
like trying to minimise the variety of components on the board so this
value was chosen, though it could be changed if there was a good reason.
I note that the DG419 has a typical channel capacitance of 35pF, which
is 3.5% of 1nF. My question is, does this matter, i.e. will it upset the
filter: do relatively low capacitances hanging on its output affect the
feedback loop? The op amp is a NatSemi LMP7702.
Nemo
switch (DG419).
Nemo
