Looking for a Multiple FM frequency transmitter for simultaneous music streams
andy taylor
Dec 29, 2016
5
I am looking to find a device that can transmit multiple simultaneous music streams each to a different FM frequency that can be selected. Each music stream would be from a separate device (smartphone/laptop/mp3) and uses the headphone jack to connect to the device. Range within 200 meters. FM frequencies should be able to be selected (ie to only broadcast on an empty frequency) manually. Battery operated great or mains not a problem either. 4-10 channels if possible.
Thanks for any help you can provide.
Andy
14,317
I don't know a suitable multiple transmitter. I suggest you use several simple single transmitters as can be used to listen to music from your MP3 player on your car radio.
Make sure you observe local regulations concerning the use of radio frequencies in the FM broadcast spectrum.
andy taylor
Dec 29, 2016
5
Thank you, i have tried having multiple car transmitters and it works ok but each needs its own power source (cables cables and more cables) and the range is only around 30 meters diameter, i need something a little more powerful and as long i i keep it under the 150-200 meter range here i am ok legally but will check that out officially. Would be nice to have something more compact, i can probably make up a multiple stacked FM transmitter board but if i can buy something to test it out would be preferred.
sundy
Aug 5, 2016
64
andy taylor
Dec 29, 2016
5
This looks like just the thing i am looking for, dad is an electronic engineer so he can help me put it together. Looks like tho they have discontinued selling this product know anything about that?
andy taylor
Dec 29, 2016
5
Thank you, thank you. I think a set of 4 of these will do me just fine. do you know the effective range? from the map it looks like1km or so?
sundy
Aug 5, 2016
64
Too many variables to say. If you on top of a hill with no obstacles to your receivers a 1km or more is probable. If you are down the hall behind a block wall with a metal fire door it might only be 50 feet.
andy taylor
Dec 29, 2016
5
perfect i will be using on a big beach/open park. I will get one and give it a test. Again thank you :)
GhostLoveScore
Nov 27, 2016
71
I say be very careful. As a radio amateur I know how high fines for illegal use of RF spectrum are. There are extensive laws for hams and what we are allowed and what we aren't allowed to do. I am messing with TV transmitters too, but what I do is always limited to at most 30m range. Transmitting sound on commercial FM frequencies over 1km range - you could get in trouble.
14,487
Agreed
COMREG is the authority for licencing legalities in Ireland
https://www.comreg.ie/industry/radio-spectrum/licensing/
. I would be extremely surprised if your can transmit signals in the FM band over a 200m or so range
you would interfere with every FM radio receiver in the area ...
I see a lot of very upset people complaining to the authorities in your future
here is a list of exempt transmitter/transmission types
https://www.comreg.ie/industry/radio-spectrum/licence-exemptions/list-of-licence-exemptions/
broadcasting .....
https://www.comreg.ie/industry/radio-spectrum/licensing/search-licence-type/broadcasting-services/
and also ... if you are broadcasting "commercial music" .... music produced by any band, group
that you didn't produce, you will also need to be paying royalties for the use of that music
sundy
Aug 5, 2016
64
I have no knowledge of European regs concerning RF transmission. What I do is find an un-used frequency and transmit on that frequency.
GhostLoveScore
Nov 27, 2016
71
Laws are similar everywhere. What is the power of your transmitter? How big is its range?
14,487
that doesn't make it legal ;)
