Looking for an appropriate RF IC
Haseeb
Jan 14, 2017
7
Hello, I'm looking for VHF-UHF RF IC. Preferably in the range of 25MHz to at least 1100MHz. I've been looking in TI, NXP and Semtech... But no luck. Last I was involved in all this was more than 10 years... I'm kinda out of loop. Can anyone help?
Thanks.
14,487
Thanks.
range you want is too wide
what are you trying to do ?
Haseeb
Jan 14, 2017
7
Basically trying to make a radio scanner of VHF and UHF band... also need to listen 1090MHz cuz of aviation ADS-B band...
14,487
OK this will be a pretty serious project. what electronics experience do you have ? does that include RF electronics
have you built any other significant electronics projects before ? example ?
Haseeb
Jan 14, 2017
7
I've worked on Intel 8051c micro controllers, made a 2D CNC out of it interfacing it with a PC on parallel and series... Also worked on GSM integration on the same micro controller... But this was all about 12 years ago.
I have an electronics engineer working with me on this... but he's having trouble understanding what parts should be used and how.
14,487
I suggest you search for a copy of a commercial scanner ... eg Uniden, Realistic
and get an idea what is involved ... as I said before .... pretty complex
RF design is VERY different to micro or audio design
Haseeb
Jan 14, 2017
7
I am trying.. the problem is... They have custom chip, thru and thru. I have a Uniden and trying to reverse engineer it, but they hardly have anything off the shelf...
This project is intended for a commercial design, but I still need a prototype to move forward.
Haseeb
Jan 14, 2017
7
Taking a lateral approach, can USB DVB-T circuit help? It has 25Mhz to 1.7GHz.
