Looking for infoand availablity of cPV
Phillip
I like the idea of cPV, but I have not found them available for homes. Is
there any place I can find them? I in the Oakland area of California.
Phil
Phillip
Since this was the PV group I thought it would be a well know term. Sorry. I
am just starting to do research.
cPV is concentrator photovoltaic technology. It uses lens and/or mirrors
to concentrate the light on the silicon. Mirrors and lenses are cheaper than
silicon -see here for a utility plant system
(http://www.ecogeek.org/content/view/1976/83/) Or do a google on cpv or
concentrator photovoltaic.
By concentrating sunlight more than 1,000 times, the system makes
electricity cheaper than traditional PV systems.
I am wondering if there are any systems designed for HOME use. Even though
they use less silicon, do they need the same size yard footprint (read these
articale, it lots like the use a lot less, but how can you get more light
out of the same size spot, or are they THAT much more effecient??!!
Phil (sorry for the assumption, as I am wiping egg of of my face...)
Eeyore
busdweller said:
Hi Kids
I can only assume that having lens or mirrors reflecting /
concentrating sunlight more than 1,000 times would generate more power
but most likely shorten the life of the panels.
Probably melt them actually. Silicon as used in semiconductors stops being a
semiconductor at about 200C when intrinsic conduction takes over from extrinsic
conduction.
In any case, the PV panels lose efficiency as they get gotter, so the entire idea
is counter productive.
These are the temps you get when you concentrate sunlight/
http://en.wikipedia.org/wiki/PS10_solar_power_tower
Graham
Eeyore
conduction.
Strangely I don't see a figure there but 420C comes to mind from somewhere else.
Enough to produce high pressure steam for sure to run the turbines.
Graham
