Looking for PS glitch with Tek scope?
Gary Walters
I have a machine in that I suspect the PS (+24vdc) is sagging under load
which is causing all kind of havoc with the digital circuits. The load is
brief, so I've not been able to capture it with a DMM.
I borrowed a Tek TDS410 digitizing scope. It's quite complex (to me, anyway)
and I'm not sure how to view the PS such that I can capture a sagging output.
I've used a 465 decades ago and a 2467 more recently, but the digitizing
scopes are new to me.
There's all kinds of capture modes (sample; peak detect; envelope; average),
measurement modes (high; low; max; min; 16 others), and trigger modes (auto;
normal; rising edge; falling edge).
I presume that I set the trigger just below the output voltage (ie, 11.80v),
falling edge, and activate the load. Beyond that, it's a mystery to me.
The site is a bit of a drive, so I've been practicing in my shop with a
stand-alone PS.
I've looked on-line for an operator's guide, but all I've been able to find
is a service manual (TDS410/420/460) which has not much in the way of setup
and operation.
Any suggestions regarding the best combination of features to use for this
simple task would be most appreciated.
Thanks.
GW
W
Winston
http://www2.tek.com/cmswpt/madetails.lotr?ct=MA&cs=mur&ci=9211&lc=EN
Top of the control panel to the right of the display is the
'General Purpose' knob. Just to it's right is a button labeled
'Autoset'. Hang your probe on the power supply and press the
'Autoset' button. Your scope will now be initialized at a good
starting point. From there, adjust trigger polarity and level,
'sweep' speed, memory depth. Bob's your uncle.
If you get into a puzzling situation where you can't see the trace
or can't get the scope to trigger, just pop the 'Autoset' button
again and you will be getting good data in no time.
I really like the Tek TDS series. Clearly the user interface was
designed by an actual scope user rather than just a software
(Cough Agilent cough) engineer.
--Winston
JW
Which Agilent scopes are you referring to? I like the 548XX Infiniium
series...
W
Winston
in Message id:<[email protected]>:
series...
Can't recall the model number. It was a fancy 4 - channel color DSO.
Looked very similar to:
http://www.home.agilent.com/agilent...&cc=US&nfr=-536900125.0.00&pselect=SR.General
I found the user interface counter - intuitive because some of the
controls wouldn't do their function apparent from the labeling.
It was sort of "You can't get there from here."
Perhaps they have improved greatly in the intervening 16 years.
I certainly hope so.
Have you used a TDS? Those are really nice. A very easy migration
to digital storage technology for those of us that started with tube -
type 'recurrent sweep' scopes. Even the 'help' system was easy to
understand and actually had helpful information.
--Winston
JW
Yeah, that model is similar to the one I was talking about. Mine is a
54845A - a bit less capable. I like that series, but it may be due to it's
PC interface and pull-down menus. I've gotten so used to PC interfaces I
actually use the mouse to control the scope more than the actual front
panel.
The latest model I've used is the TDS7XX series. I like them as well, but
would still take the Agilent over it any day.
My first scope at work was a Tek 465, then a 2465B. Even had a 434A analog
storage type at home. But once you go digital, you never go back. At least
with me, anyway. :) Many die-hards would think of me as a blasphemer, I
suppose.
14,484
[QUOTE
suppose.[/QUOTE]
My poor ol' TEk 465B has recently fallen over and the horizontal trace is jumping wildly all over and off the screen. Its proving very difficult to find the fault.
Blaspheming not quite. ;) but there is the harshness of a LCD panel scope be it a Oscilloscope or a Spectum An that I just dont like, I like the smoother trace on a CRT compared to the chunky curves of a waveform on an LCD screen
Yes there are times I would like a digital storage scope for capturing waveforms, that would be handy
cheers
VK2TDN
