Looking for receptacle lube
12vdc
Apr 13, 2011
46
I have a power cord for (for a flood lamp) that I insert and remove often, is there a lube for 120 Vac contacts for a receptacle / plug ?
( I wifi at the moment :D )
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
I have used a silicone lubricant for such things, Dow Corning Vacuum Grease, which is intended to lubricate fritted glass-to-glass rotating seals such as stop-cocks. A metal-to-metal contact pushes the lubricant aside and the lubricant seals out the entry of air. I have also used petroleum jelly (Vaseline) for the same purpose, but it melts at a low temperature and is somewhat messy. If you can find it, distributor cam lubricant might be an inexpensive alternative. Whatever you use, a very thin film is all you need.
KJ6EAD
Aug 13, 2011
1,114
In addition to Hop's suggestions above, all of the following will work:
dielectric grease from any electrical supplier is pretty optimal; O-ring grease from an industrial supply or auto parts store; plumber's grease (an O-ring grease) from a plumbing supply house or home improvement store; food service grease from a food service distributor or a friend in a business with a soft serve machine. All of these are silicone greases and will form glasslike silicates in the presence of an arc (a minor problem in connectors, a bigger issue with switches and relays) so it's best to make and break the connection unpowered if possible.
You can use WD-40 but it's not really a lubricant and CRC 2-26 or CRC 5-56 are also options. These "light oil in a spray can" products have the advantage of flushing dirt and debris from the connector when used which may be helpful in some conditions.
12vdc
Apr 13, 2011
46
I am not confident using anything petroleum based near potential sparks/heat.
Hmmmmm?
12vdc
Apr 13, 2011
46
The lamp is 500 watts and the plug/receptacle contacts arc when connected or disconnected.
Thanks for the replies.
Minder
Apr 24, 2015
3,561
Keep in mind that dielectric grease is an insulator and moisture repelant, One reason it is used in spark plug insulator covers.
M.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
I hate when that happens! That's what switches and contactor relays are for.
Tha fios agaibh
Aug 11, 2014
2,253
Same with receptacles, they are rated for plugging/unplugging hot.
The plug/receptacle should not be that hard to unplug. If so id be looking at the receptacle, not putting lube on it
