K
[email protected]
- Jan 1, 1970
- 0
Hi
I have an access control system running off a float charged battery.
If there is a power outage of +-8 Hours, the battery drops to a level
lower than the access-control system can handle, and then it does not
recognise the tags (the readers actually lockup, but the maglocks stay
locked).
I was thinking of putting a 9v zener diode on the battery, running a
relay coil, that will cause the load to be disconnected when the
battery is at 9v. one problem i see with this is that when the load is
disconnected, the battery can 'bounce' up to above 9v again, which
will cause the relay to keep on chattering,.
Is my understanding correct, and is there an inmprovement that will
eliminate the chatter
BATTERY --------------------------|> ZENER DIODE------- RELAY COIL
---------------------------------------------------------- RELAY COIL
locked).
