[LTspice] Why does NMOS netlist with 4 nodes?
Chris Carlen
Hi:
The symbol nmos.asy included with LTspice only has 3 pins, yet this
symbol when included in a schematic netlists with 4 nodes.
Why is this?
Thanks.
_______________________________________________________________________
Christopher R. Carlen
Principal Laser/Optical Technologist
Sandia National Laboratories CA USA
[email protected]
NOTE, delete texts: "RemoveThis" and "BOGUS" from email address to reply.
Chris Carlen
Joerg said:
The M Spice primitive certainly has 4 terminals. But LTspice has both a
3-terminal and 4-terminal MOSFET symbol. The 3-terminal symbol netlists
4 nodes. I am simply curious as to how this occurs, since it is
inconsistent with the symbol's 3 terminals.
Good day!
[email protected]
Jim Thompson
Good day!
Netlists as
MN1 %d %g %s %s ModelName L=...
...Jim Thompson
H
Helmut Sennewald
Chris Carlen said:
Hi:
The symbol nmos.asy included with LTspice only has 3 pins, yet this symbol
Why is this?
Thanks.
Hello Chris,
This fourth pin is normally connected to the substrate of a
monolithic MOSFET.
LTspice automatically connects this 4th pin to the source in the
netlist even when only a 3-pin symbol is used for a MOSFET.
It's simply convenient to always have the same syntax in the netlist.
The 3-pin symbol is intended for VDMOS and other MOSFETs with 3 pins.
There is also a 4-pin MOSFET symbol in the components library
especially for monolithic MOSFETs.
Best regards,
Helmut
Jonathan Westhues
I notice that it only does that when the symbol is netlisted with an `M'
prefix; if I use an `X' prefix then it netlists with only three terminals,
which is exactly what is required to run most subcircuit FET models.
Jonathan
