[LTSpice] Why is 1n4148 so slow?
Chris Carlen
Greetings:
A 1n4148 should have a Trr of about 4ns, but the sim gives about 15ns!
Why is that?
Version 4
SHEET 1 880 680
WIRE -16 240 -16 160
WIRE -16 352 -16 320
WIRE 112 160 -16 160
WIRE 224 160 176 160
WIRE 224 208 224 160
WIRE 224 336 224 288
FLAG 224 336 0
FLAG -16 352 0
SYMBOL diode 112 176 R270
WINDOW 0 32 32 VTop 0
WINDOW 3 0 32 VBottom 0
SYMATTR InstName D1
SYMATTR Value 1N4148
SYMBOL res 208 192 R0
SYMATTR InstName R1
SYMATTR Value 250
SYMBOL voltage -16 224 R0
WINDOW 3 -151 173 Left 0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR Value PULSE(-50 50 0 1n 1n 500n 1u)
SYMATTR InstName V1
TEXT -168 506 Left 0 !.tran 0 3u 0 1n
Thanks for input.
_______________________________________________________________________
Christopher R. Carlen
Principal Laser/Optical Technologist
Sandia National Laboratories CA USA
[email protected]
NOTE, delete texts: "RemoveThis" and "BOGUS" from email address to reply.
Jim Thompson
Greetings:
Why is that?
[snip]
Thanks for input.
Are you simulating it in a way that matches the test method on the
data sheet?
...Jim Thompson
Genome
Chris Carlen said:
Greetings:
Why is that?
Thanks for input.
Indeedy, what Jim says. Change your resistor to 100R and make your pulse 1.6
and -6V.
DNA
legg
and -6V.
Note that dI/dT in the JEDEC test set-up is determined by the
generator's fall time - "<1nS" effectively producing 76A/uSec in this
case.
This is roughly the same effect as a perfectly fast source operating
in series with 100nH - a fairly high 'stray' inductance value, but one
not totally impossible to introduce accidentally in a sloppy physical
test set-up.
dI/dT affects the peak reverse current, rate of total charge removal
and trr, with no other test characteristics being altered.
RL
Chris Carlen
Jim said:
Greetings:
Why is that?
[snip]
Thanks for input.
data sheet?
...Jim Thompson
Good point, lemme see...
Oh, I get it.
Thanks for the input.
Good day!
[email protected]
Chris Carlen
case.
test set-up.
You mean of course that it can reduce the peak Irr, by blurring it out
over a ringy-thingy, right?
I tried simulating as you are saying, by making my generator *really*
fast with 10ps rise/fall, and introducing 100nH.
That gives just about the same peak Irr and Trr for the first half cycle
of the ring.
Actually, it looks like a stray inductance I wouldn't feel too shabby about!
Well, that's if I did it on a breadboard like I do most things in a
curious hurry.
But if done on a PCB, it could be much better.
Good day!
[email protected]
