Mains Current Sensor Idea
Joe G \(Home\)
Hi All,
The concept is very simple. I want to detect / measure current in a power
board and if over a certain current switch on another device.
I was thinking of using a current transformer, rectifying it and the
voltage output would be proportional to the current.
say 10mA to 500mA on a 240V AC device ...
What do you suggest.
Joe
MooseFET
Hi All,
Yes basically you have the right idea. A transformer feeding a
rectifier and loaded with a resistor will indicate the current nicely.
Don't forget the load the output side. If you don't you get a high
voltage on it and perhaps may destroy it.
I have used a 120V to 6.3V transformer as a current transformer. The
6.3V side was in series with the load and the 120V side was loaded to
make about a volt. It worked well enough for what I wanted YMMV.
N
Nico Coesel
Joe G \(Home\) said:
Hi All,
A hall sensor over a PCB trace.
V
Vladimir Vassilevsky
How accurate?
An optocoupler. Two optocouplers for the increased dynamic range.
Isn't 10ma too small for the Hall sensor?
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
N
Nico Coesel
Vladimir Vassilevsky said:
How accurate?
Perhaps. I thought he was talking about the secondary current in the
current transformer. I guess the OP could make a coil with multiple
windings on the PCB so the Hall sensor sees a higher field strength.
mpm
Hi All,
I was thinking of using a current transformer, �rectifying it and the
say 10mA to 500mA �on a 240V AC �device ...
Joe
Notice: Now slightly "Off Topic"
Is it just me, or does anyone else squirm when they hear the words
"Mains" as referred to electric service?
To me, this is never very clear whether someone means the voltage, or
the conductors themselves - and in either case, is it at the service
entrance to the building (or other), or the wall outlet, power cord,
or power terminals of the device in question.?? Or all of the above?
Seems very loosey-goosey terminology to me. Though, generally, I
guess I know what is meant - at least in the way of "don't touch it or
you might get electrocuted". But generally, not much beyond that.
Does NEC use this terminology? I know a lot of other terms used in
NEC, but I'll have to review my copy to see if there actually is a
recognized & accepted definition for "Mains".
Spehro Pefhany
yeah, they have a reasonable selection. I wanted one RIGHT NOW, and I
got it.
I use dgikey a lot - mostly from a design-in perspective, rather than
actually purchasing components, which I prefer to do from Farnell
(quicker and I dont have to fill in any stupid "what is this for" crap).
What's that? More export controls BS? Talk about shooting yourself in
the foot..
that being said, I buy from digikey and mouser where necessary. such as,
for example, LEM DCCTs :)
Cheers
Terry
Best regards,
Spehro Pefhany
Spehro Pefhany
I think its akin to the "will all terrorists please report to the
security counter for immediate arrest" announcements at airports.
just another irritating layer of hoops for us furrners to jump thru. I
always write the same thing: intended for use in a SMPS, by me.
Well, if they keep up the stupidity, a French company is going to be
making a whole stack of Euros. The US product is half the price, (and
half as good, but good enough), but the Frenchies don't try to dictate
what happens with it once it's sold by them (or by us, or by our
customer).
hao3 jiu3 mei2 jian4
Cheers
Terry
Shenme?
Motivational management term of the day:
"We're facing insurmountable opportunities".
Best regards,
Spehro Pefhany
ehsjr
John said:
Terry Given wrote:
(snip)
Have you checked, lately, for how many different current transformers
are available from Digikey? The variety has multiplied in the last year
or two.
Good to know. Last time I needed a bunch I got them
direct from Toroid Corporation of Maryland, but that's
a while back.
Ed
